Old 11-01-2019, 09:45 AM   #1
Mulletwagon
Mulletwagon's Avatar
Default Rear Spring
Planning on changing the rear spring on the 31 Tudor. Should I go 8 leafs or 10 leafs ? Does any supplier provide springs made in the good old USA ?
Mulletwagon is offline   Reply With Quote
Old 11-01-2019, 10:19 AM   #2
alexiskai
alexiskai's Avatar
Default Re: Rear Spring
Bert's and Snyder's both sell US-made 10-leaf rear springs
Old 11-02-2019, 05:04 PM   #3
Mulletwagon
Not getting much insight. How many leafs were originally on the rear springs of the Tudors. I can count at least six on mine but more are shielded by the frame shrouding retaining the spring. Thinking there is probably no noticeable ride difference between an 8 or 10 leaf unit. Watcha think ?
Old 11-02-2019, 05:33 PM   #4
Curtis in MA
Check out A-Springs.com in Ct.
I think 10 for the heavier cars and 8 for the coupes and roadsters.
Curtis in MA is offline   Reply With Quote
Old 11-02-2019, 05:42 PM   #5
Joe K
Joe K's Avatar
Tom Wesenberg has brought us Marco's "Spring Chart" before. The link is https://fordbarn.com/forum/showthread.php?t=62383 but unfortunately the picture is blurry being sourced at one of the no longer functionable photo hosting sites.
Still, Tom gives us the description of the Model A springs and their application.
A is for body style 55A, 130A, 140, 295A (10 leaf)
Tudor, Delux Delivery, Town Cars
B is for body style 35A,B; 45A,B; 49A; 50A,B; 68A,B; 190A (8 leaf)
Phaeton, Coupes, Fourdor Steelback, Vicky
C is for body style 40A,B (7 leaf)
Roadster
D is for body style 60A,B,C; 130A,B; 155A,B,C,D; 165A,B,C,D; 170A,B;255A (10 leaf)
Fordor Leatherback, Delux Delivery, Town Sedan (Murray & Briggs), Fordor (Murray & Briggs)
E is for body style 76A,B; 78A,B; 79A,B; 82A,B; 85A,B; 150A,B; 225A (10 leaf)
Pickup, Panel Delivery
Thanks Marco for all the time you spend to do research and post valuable information!
As I was about to say, there are THREE 10-leaf spring variants out there, and it would appear that the Tudor was originally a 10 leaf.
Not to say that you might not go to an 8.
BUT - you may find a distinct difference between the three 10-leaf versions - I know for fact that the truck spring is QUITE stiff - as befits it's non-complaining majority load.
And - unless you find the part number with the applicable end-letter stamped into the spring clamp, it may not be possible to tell one from another without getting serious about measuring the spring, understanding it's make-up (including leaf thicknesses) and determining positively which it is. Not an easy task - but made easier by buying new and selecting your number from the vendor offerings.
Most retailers now sell quality rear springs - at least for the rear. There are still a couple of JC Whitney type front springs out there in retail land (i.e. converted trailer springs) so be careful of that.
The head and shoulders source for springs (where most retailers source them now) is www.a-springs.com
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 11-02-2019, 06:05 PM   #6
Mulletwagon
Joe K - You da man !!
Thanx
Old 11-03-2019, 01:58 PM   #7
Patrick L.
Patrick L.'s Avatar
I would think it has, or came, with a10 leaf, but, I think it would depend on what type of ride you're looking for. Do you want a soft or firm ride ? Do you have rear passengers often ?
Old 11-03-2019, 07:30 PM   #8
Mulletwagon
Going with a 10-leaf. More concerned with ride height and zero lean than comfort. Only backseat riders are the grandkids - comfort not an issue.
Old 11-03-2019, 07:53 PM   #9
ursus
Good idea! Henry Ford put 10 leaves under the rear of the Tudor for a reason.
ursus is offline   Reply With Quote
Old 11-03-2019, 08:12 PM   #10
Joe K
Joe K's Avatar
We'll need to find you a complete chart then, so you'll be able to measure up what you see and get the CORRECT 10-Leaf.
Right now Marco Tahtaras' most excellent site www.abarnyard.com (the original site for a long while) seem inaccessible.
I'm not finding the chart anywhere else online. I know I posted it once minus the descriptive given by Tom, but I'm not even finding that.
Joe K
Edit: I found the complete colored spring chart on an attachment by wrndln
Can be found at https://www.fordbarn.com/forum/showthread.php?t=174402
Note that the cross-hatching and colors shown on the RH side of the chart indicates "cross sections" of the various leaf elements. A 10 leaf spring can be made up of "weaker" (thinner) spring leaves (A) or thicker leaves. (E particularly but D more so than A)
Old 11-03-2019, 09:13 PM   #11
CT Jack
CT Jack's Avatar
The resource for Model A springs is Travis Cook at www.a-springs.com. Travis supplies most of the parts dealers.
CT Jack is offline   Reply With Quote
Old 11-03-2019, 09:26 PM   #12
WTSHNN
WTSHNN's Avatar
Seconding Travis. Very knowledgable. I bought a full set of his bronze bushings at Hershey for my phaeton project.
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Thread Tools
Display Modes
