11-23-2017, 10:13 PM | #1 |
Crud in tank and lines
Ok, left the ethanol gas in my tank and lines. Thought i had run the carb dry but now i have clog lines etc. I have drained the tank, will clean the lines and carb but what do you guys recommend to clean the tank,
I hear it 'crystalizes' but do not really know? Just want to make sure i flush it good before adding fresh gas if this is necessary Thanks to all and Happy Thanksgiving |
11-23-2017, 10:57 PM | #2 |
Re: Crud in tank and lines
If you live in a free State that has the choice of real gas or corn gas, I would fill her up with real gas.
And run a filter...after you clean everything out of course. And a very Happy Thanksgiving to you also
11-23-2017, 11:29 PM | #3 |
Clean the lines and filter add new gas and drive. Oh you might add one of the pencil filters to the shut off valve.
11-24-2017, 05:02 AM | #4 |
I am finishing up an in place purge of the tank with 10 gallons of Evaporust. I first used Oileater to cut the goo out of the tank. I left the Evaporust in the tank for 30 hours. LOts of scale and crud came out. I flushed the tank with water and then re loaded the came Evaoprust, minus the sludge back in and out again and let the tank dry. I blew the tank out with a leaf blower. Used cloth diaper to mop up the water(I have a 18 inch long pair of needle nose plyers to grad the diaper.) Lots of crud sticks to the diaper. I could not get the petcock out, so I rebuilt it in place. The crud left in the tank is white particles that sort of float. they are not magnetic. We installed a inline glass micro filter. Start up is soon. I expect to use several filters. I'm not convinced the tank is clean yet. Many say the only fix is remove the tank and commercially clean it.
11-24-2017, 07:55 AM | #5 |
thanks for the advice!
11-24-2017, 08:45 AM | #6 |
I Love Anything That Turns Money Into Noise |
11-24-2017, 11:26 AM | #7 |
My team advises against the Petcock filter. Apparently is plugs up and the what?
11-24-2017, 02:02 PM | #8 |
You could use one of these for a while to get it cleaned while enjoying your A, Thanks to supplier of photo.
www.whidbeymodelaclub.com |
11-24-2017, 04:11 PM | #9 |
Petcock filter is open on top. Keeps the dregs in the bottom of tank out of the line.
11-25-2017, 08:27 AM | #10 |
The Petcock filter I have has a screen on top as well as the sides. The debris I see is opaque and soft. Almost like mucus. I'm sure it w ill clog the micro filter we put inline.
11-25-2017, 09:47 AM | #11 | |
You could use tin snips to cut off the top your screen or buy one ready made. Snyder’s P/N A9193T
11-25-2017, 09:34 PM | #12 |
thanks
11-28-2017, 09:39 PM | #13 |
I continue to try and clean the rusty tank. I now have a couple of inches of gas from my garden gas container. It is old. I added it to an empty and dry tank. I used the small amount to check the petcock valve. A day later I had 1/2inch of water in the tank. A day later I can see a skim of floating stuff over the gas. I'm out of ideas.
11-29-2017, 12:27 AM | #14 |
Did the tank have a liner stuff put in it at some prior time? Sounds like maybe this could have happened and the stuff is coming off the tank.
Fred Kroon 1929 Std Coupe 1929 Huckster |
11-29-2017, 03:12 AM | #15 |
We don't see any evidence of a liner. I can scratch the inside of the tank with a screw driver.
11-29-2017, 07:27 AM | #16 | |
If this is the tank that you could not get the fuel shut-off valve out of, how are you going to install that pencil standpipe filter? |
11-29-2017, 10:33 AM | #17 |
Brent,
thanks for the post. Same car. We thought we'd give this procedure a try. We strapped in a temp tank to run the engine to see if our head replacement work works. We bought Evaporust in 5 gal tubs and shipped by Amazon with cut the costs sig. We gave up with the idea of the petcock filter based on comments locally that it will clog up. Up tp the owner as to what o do next |
11-29-2017, 03:48 PM | #18 | |
I understand totally. It is a large expense to restore a tank by the time you remove, restore, repaint, & replace. Unfortunately, it is also the reason why many people do not enjoy their Model-As any longer, ...simply because of the stress those little rust particles create. |
11-29-2017, 04:50 PM | #19 |
I can confirm that those little rust particles can be a real PITA. I have just fixed that problem in my CCPU (which came out of the US and had rust in the bottom of the tank, no doubt because of ethanol fuel. I cleaned and sealed the tank with the same stuff I used about 15 years ago in another car and still no sign of a problem.
As with most things, preparation is key to a good result. The process outlined in the instructions involved first using a caustic cleaner to remove any residual traces of fuel so that the Phosphoric acid could do its work (2nd stage). I have found that something more potent may be required so I used Hydrochloric acid (brick cleaning acid) diluted about 10:1 with water. That left the rusty area free of rust ready for the sealer. (Dry thoroughly between stages). I think tank sealers have an undeserved bad reputation due to either a poor product h=years ago or instructions not being followed precisely. A good quality sealer (and there are plenty of them) properly installed is nothing to be afraid of.
11-30-2017, 08:22 AM | #20 |
Is there a modern product like "Slosh around" that I can put in the tank to seal it without removing the tank
Thread Tools | |
Display Modes | |
