03-30-2017, 01:16 PM | #1 |
E brake setup using stock pivot for hydraulic conversion 35 - 36
someone had a nice writeup with pictures for e brakes using the stock brake pivot on a 35 or 36. Does anybody have the link, i cant find it again.
Thanks!
Throttle Benders Est. 1949
03-30-2017, 04:20 PM | #2 |
Re: E brake setup using stock pivot for hydraulic conversion 35 - 36
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
03-31-2017, 04:02 PM | #3 | |
Thanks!
01-03-2021, 06:40 PM | #4 |
BUT Another option is to look up and call "Control Cables" Speak to the owner and he will walk you through everything you need and they will give you everything including cut to size cables. Buying everything from one company means everything is compatible and fit together. |
