Old 01-23-2014, 03:00 PM   #1
farmputzer
Default Finish on body mounting bolts
The finish on body mounting bolts is a dipped black paint. Was this a very thin coat of paint? How did Ford prevent chipping the paint on the head when tightening them?
farmputzer is offline   Reply With Quote
Old 01-23-2014, 03:38 PM   #2
Marco Tahtaras
Marco Tahtaras's Avatar
Default Re: Finish on body mounting bolts
A thin coat of alkyd enamel over properly cleaned steal is very durable. It may wear through or abrade, but it will rarely chip unless the paint film thickness is excessive.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-23-2014, 09:01 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by 1930 coupe View Post
I do not think Ford was concerned with wrench marks on bolts. If you do not have any wrench marks some will call it OVER RESTORED.
GREAT ANSWER!!!!!! I would NEVER try to do a high points car, for fear of dieing from ULCERS!
I'd much rather die frum LAFFIN' myself silly & be cremated with my RUBBER CHICKEN.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-24-2014, 06:08 PM   #4
ericr
ericr's Avatar
I might be misunderstanding all of this, but what I am looking at suggests that the paint disappeared from the bolts except where protected by the mounting blocks....am I wrong, it happens all the time LOL
ericr is offline   Reply With Quote
Old 01-24-2014, 07:21 PM   #5
Marco Tahtaras
I realized awhile after I posted that it may confuse the issue. I just threw the pic in because it was handy. These have been well exposed to the elements. However the square under the head of the carriage bolts only received paint damage upon removal as the nuts were stuck a bit.
