Old 05-18-2020, 04:05 PM   #1
Ken/Alabama
Ken/Alabama's Avatar
Default Rod Clearance
Installing a Scat 4 1/4”” stroke crankshaft and H beam rods in a 59A block. What’s the minimum clearance I can get away with between the rod and the bottom of the bore. ? I can get a .070 feeler gauge between the rod and block.
File Type: jpg BC1E92EB-7732-48E6-AE03-3D1116AB2596.jpg (27.1 KB, 82 views)
Old 05-18-2020, 07:08 PM   #2
tinkirk
tinkirk's Avatar
Default Re: Rod Clearance
My personal opinion is i would be grinding a spot in the block to the rod will clear and get more clearance
Wish I could tell u how much to take out but more id better than not enough
tinkirk is offline   Reply With Quote
Old 05-18-2020, 07:11 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
Usually on a stroke that big some lower bore relief is needed. I use a plastic Ty-rap to check clearances the ones I have measure a bit more than the .070 When I can get the Ty-rap in between the rod and bore I stop grinding I like to see at least .100
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 05-18-2020, 07:25 PM   #4
Ken/Alabama
Ronnieroadster
I’ll try a ty rap ,haven’t thought of that . My feeler gauge blade is a little wider than the H beam rod so I might have more clearance than I think .
Old 05-18-2020, 08:24 PM   #5
Phil Gillespie
Phil Gillespie's Avatar
Just been reading on such items seem to recall a figure of 0.110 quoted for this clearance.
Phil NZ
Phil Gillespie is online now   Reply With Quote
Old 05-18-2020, 09:07 PM   #6
Ken/Alabama
Phil NZ
Does everything really grow that much when the engine is hot. ??
Old 05-18-2020, 09:22 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
Ronnie's 0.100" surely seems to work for him, and I've seen HIS tach buzzing near 8 grand-ish! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 05-18-2020, 09:30 PM   #8
Ken/Alabama
Sounds like I need to pull the crank and valve train back out and do some grinding and flushing.
Old 05-18-2020, 09:48 PM   #9
Ronnieroadster
Its worth the effort I can say from experience rod clearance is extremely important. Just go easy on the cylinders towards the oil pan rail side of the bore that area is not extremely thick. The area towards the inside /center of the block is a bit thicker at the bottom of the bore from what I have learned.
Ronieroadster
Old 05-18-2020, 10:12 PM   #10
Ken/Alabama
Ronieroadster
Thank you.
Old 05-18-2020, 11:40 PM   #11
GOSFAST
GOSFAST's Avatar
Assuming you have a 3.312" bore size you will be fine with .050" for a "streeter", it's all you really need!
We've sent dozens out with .050" clearance and absolutely no grinding using the 3.312" bore x 4.250" stroke! It's not an issue unless you "spin" a rod brg!
The only time we've found it necessary to grind in any add'l clearance is when you have the 4.250" stroke and the bores are smaller than the 3.312", e.g., for an .080" o/b you'd be grinding some!
Thanks, Gary in N.Y.
P.S. Due to the limited amount of room in this area it is the main reason we use the Scat rods, they will clear, the Eagle H-beam rods with a 1.100" beam width will NOT go with the 4.250" stroke in the program!
GOSFAST is offline   Reply With Quote
Old 05-19-2020, 01:49 AM   #12
Lawrie
Lawrie's Avatar
Gary, what if you used the 21a rods,
Lawrie
Old 05-19-2020, 04:53 AM   #13
Ken/Alabama
Yes, it’s 3.312 with the Scat rods.
Old 05-19-2020, 08:15 AM   #14
GOSFAST
GOSFAST's Avatar
Lawrie
Hi Lawrie, I would surmise due to the difference in the beam widths on the Scat (.790") and the OEM type rods (.710") you'd have more room with the OEM's?
The Scat rods are reasonably "straight" along the beams from top to bottom while the OEM's are tapered some. The area of contact at the bottom of the bores is about where the sizes are written on the beams?
P.S. Here's a shot of both rods comparing the actual beam widths, you can see there would some slightly add'l room with the OEM's.
File Type: jpg Flathead Conn Rods - Scat vs OEM Widths.jpg (61.5 KB, 44 views)
Old 05-19-2020, 05:31 PM   #15
Lawrie
Lawrie's Avatar
OK , the originals would be better though if using the floaters ?.
Lawrie
