05-13-2022, 11:40 AM | #1 |
Headlight bulb
What is the smaller bulb in the headlight assembly for ? running light ? , thinking about going with LED's but wanted to know what the small bulb does
Vern |
05-13-2022, 11:41 AM | #2 |
Re: Headlight bulb
Sorry , left out it is a 1931 model A
05-13-2022, 11:47 AM | #3 |
Re: Headlight bulb
Parking light.
The Master Cylinder Enjoying life at the beach in SoCal... |
05-13-2022, 11:50 AM | #4 |
Re: Headlight bulb
Thanks , that's pretty much what I thought
05-13-2022, 02:29 PM | #5 |
Re: Headlight bulb
Put a 10 cp bulb in a use as a DRL ( day time running light)
05-13-2022, 03:51 PM | #6 |
Re: Headlight bulb
05-13-2022, 06:00 PM | #7 |
Re: Headlight bulb
Not familiar with a 10 cp bulb , why not just use the #67 bulb for drl
05-13-2022, 06:23 PM | #8 |
Re: Headlight bulb
The normal bulb is 3cp, 10cp bulb you could drive in town after sunset
05-13-2022, 09:11 PM | #9 |
Re: Headlight bulb
Makes sense to me , thanks
05-13-2022, 09:50 PM | #10 |
Re: Headlight bulb
05-14-2022, 05:54 AM | #11 |
Re: Headlight bulb
I change the bulbs from 3cp to 10cp. MUCH brighter and will fire a thermal flasher if needed. I can't remember the number though without running out and looking.
05-14-2022, 06:54 AM | #12 |
Re: Headlight bulb
Just wondering. Has anyone used the headlight as turn indicators? Not the parking lights but the normal headlight bulbs used for night driving. It would get people's attention. There is probably some law against doing that.
05-15-2022, 11:33 AM | #13 | |
Re: Headlight bulb
Still did it on EVERY bug that I've owened just because it looks so much better but you just need to remember that most likley people comming at you cannot see your signal. |
05-15-2022, 12:57 PM | #14 |
Re: Headlight bulb
05-16-2022, 01:21 PM | #15 |
Re: Headlight bulb
