Old 04-26-2022, 04:15 AM   #1
jtminor
Default Bubbling gas tank
Bubbling gas tank - on a recent outing with my 1949 Ford F1 the engine kept stalling, finally on the last mile to home it started to run smooth again. When I pulled into the garage and shut the engine down I heard a bubbling sound. At first I thought it was the radiator , but it was the gas tank. After a few minutes I took the gas cap off, a great deal of pressure was released and the bubbling stopped. I have no idea what was going on, any suggestions.
jtminor is offline   Reply With Quote
Old 04-26-2022, 06:02 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Bubbling gas tank
I believe the gas cap should be vented to prevent vacuum or pressure in the tank. I know 40 has the vented cap, I am not sure of 49.
Old 04-26-2022, 06:27 AM   #3
nelsb01
nelsb01's Avatar
1949 Ford passenger vehicles had vented gas caps. How do I know?
Lost my cap on a road trip, and used a plastic bag to cover the filler opening. A rubber band was around the edge to hold it on. At that next stop, the plastic bag had been sucked into the filler opening. Glad I used the rubber band to hold the plastic bag on -- or else it would have gone into the tank.
Try a vented cap and see if that changes things.
nelsb01 is offline   Reply With Quote
Old 04-26-2022, 01:38 PM   #4
jtminor
Where can I get the correct vented gas cap ?
Old 04-26-2022, 04:06 PM   #5
deuce lover
deuce lover's Avatar
Here,V8 Ford Sales in Piedmont SC.Maybe Midwest Early Ford in Springfield OH has them also.
FUEL CAPSS LIKE ORIGINAL 32-48 PASS & 48-50 PU
  • Year1932-1950
  • Item#11C-9030
  • Price$12.00EACH
deuce lover is offline   Reply With Quote
Old 04-26-2022, 06:54 PM   #6
TJ
TJ's Avatar
  • Year1932-1950
  • Item#11C-9030
  • Price$12.00EACH
Napa Auto Parts also carries them. Part #703-1020. I think about the same price. I carry a spare in my tool kit.
Old 04-26-2022, 07:25 PM   #7
paul2748
paul2748's Avatar
Drill a 1/16 hole in your cap
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-29-2022, 03:26 PM   #8
jtminor
What would happen if you drive without a cap on.....
Old 04-29-2022, 06:16 PM   #9
FortyNiner
FortyNiner's Avatar
You would likely introduce a steady path for crud in the tank, have a ready source for fuel odor, and invite fumes to find an ignition trigger outside the combustion chamber.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 04-29-2022, 07:27 PM   #10
Lawson Cox
Lawson Cox's Avatar
  • Year1932-1950
  • Item#11C-9030
  • Price$12.00EACH
That cap ain't "Like original" Originals do not have that unsightly "ring" around the outer edge". The entire cap has a smooth and gentle crown from top to edge.
Old 04-29-2022, 07:28 PM   #11
Lawson Cox
Lawson Cox's Avatar
That cap ain't "Like original" Originals do not have that unsightly "ring" around the outer edge". The entire cap has a smooth and gentle crown from top to edge.My 2¢.
Old 04-29-2022, 07:54 PM   #12
TJ
TJ's Avatar
You can also get a traffic ticket.
Old 04-30-2022, 06:54 AM   #13
Terry,OH
Terry,OH's Avatar
Drake reproduces a vented gas cap for the 36-48/50 pick-up It appears identical to the original cap. His part number 18-9030 is somewhat misleading since the early cars did not use a vented cap. The idea of drilling a 1/16" hole in an unvented cap could very well work since that is what Ford had done. I believe the 49 filler uses a smaller cap than the earlier Fords, if so this cap would not work on the 49 car but would should work until 50 on the PU.
Old 05-01-2022, 02:09 PM   #14
joe 1950
joe 1950's Avatar
On my 50 cpe had the stalling problem the cap had plugged up wanted nice chrome one took the one off my Harley worked perfect so i went to my Harley dealer and bought another looks and works great but then again who can see it
joe 1950 is offline   Reply With Quote
Old 05-01-2022, 02:47 PM   #15
Flathead Fever
Flathead Fever's Avatar
What then would vent the tank on a early car if it wasn't the cap? There "must" be a vent somewhere.
Flathead Fever is offline   Reply With Quote
Old 05-01-2022, 07:18 PM   #16
TJ
TJ's Avatar
As I recall it is vented through the early style gas gauge sender.
Old 05-02-2022, 06:47 AM   #17
Terry,OH
Terry,OH's Avatar
Yes the earlier Fords vented the tank through the hydrostatic fuel sender and pick up 32-35. If a vented cap is used on these early cars, fuel often leaks in the area of the cap.
Old 05-14-2022, 09:43 PM   #18
jtminor
Drilled hole in Cap, drove about twenty miles, then it stalled again, what do you think is going on...??
vapor lock?
Gas cap?
Dirty fuel line?
This has happened twice this spring.... drove perfect last fall...
Help
Old 05-15-2022, 03:15 AM   #19
FortyNiner
FortyNiner's Avatar
Start with a check of the tank and lines.
Old 05-15-2022, 05:43 AM   #20
Terry,OH
Terry,OH's Avatar
If it stalled after drilling the hole then remove the cap and see if there is still a vacuum or pressure in the tank. If there is then the hole you drilled is not venting the tank properly.
