04-02-2021, 09:17 AM | #1 |
40 ford cpe
Looking for a how to adjustment on the shocks going to help a friend of mine get his adjusted the shocks have been rebuilt and work good
04-02-2021, 09:20 AM | #2 |
Re: 40 ford cpe
Looking at the face of the shock you'll note a small rectangular metal piece at the very center. That turns with a small wrench. Turning it clockwise makes the shock stiffer.
Counter-clockwise makes it looser - more "bounce". I am not aware of any easy method to determine when "enough is enough" on the adjustment other than to test drive and readjust as you feel may be necessary.
04-02-2021, 09:35 AM | #3 |
Re: 40 ford cpe
Thanks Kube that easy enough to do now all i have to do is flip a coin to see who’s going underneath one of us might have to lay there while the other guy goes for help www.jalopyjournal.net⚕️www.jalopyjournal.net⚕️
04-02-2021, 09:50 AM | #4 |
Re: 40 ford cpe
don’t know where that jalopy journal came from must have been crawling @ in my i pad
04-02-2021, 10:30 AM | #5 |
Re: 40 ford cpe
This may help
04-03-2021, 01:35 PM | #6 |
Re: 40 ford cpe
04-03-2021, 01:44 PM | #7 |
Re: 40 ford cpe
Glad to help.
I find the shocks to be quite good and the adjustments are very effective. I followed the recommendations given. Glenn |
