Old 06-17-2020, 08:01 PM   #1
David R.
Default Emergency brake anti rattle felt
Where does the anti rattle felt install on ‘30 emergency brake lever?
File Type: jpg 7550B26E-EF15-4CE9-8A4B-D86801406982.jpg (36.1 KB, 56 views)
David R. is offline   Reply With Quote
Old 06-17-2020, 08:19 PM   #2
FordTudor1931
FordTudor1931's Avatar
Default Re: Emergency brake anti rattle felt
The felt goes on the rod inside the emergency brake lever. It is intended to prevent the rod from rattling.
FordTudor1931 is offline   Reply With Quote
Old 06-18-2020, 10:32 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
See the Ford Service Bulletin of April 1929, Page 337. There is a sketch of the brake lever showing the installation of the felt washer.
Bob Bidonde
Old 06-19-2020, 12:28 PM   #4
David R.
Thanks Bob I will look it up
Old 06-21-2020, 06:00 AM   #5
dmaxweb
dmaxweb's Avatar
Could you post a photo of that SB page.
dmaxweb is offline   Reply With Quote
Old 06-21-2020, 11:09 AM   #6
Bob Bidonde
My scanner is broken, so I cannot post the service bulletin. Perhaps another Barner will post it.
Bob Bidonde
Old 06-21-2020, 12:07 PM   #7
Bill G
Bill G's Avatar
Screen shot of page 337
Old 06-21-2020, 03:53 PM   #8
dmaxweb
dmaxweb's Avatar
Thanks
I did not realize the lever button sleeve (A-2792) could come out of the lever tube. It sure doesn't look like it does.
Old 06-21-2020, 04:28 PM   #9
Bob C
Originally Posted by dmaxweb View Post
Thanks
I think they are showing the early to mid 1929 lever.
Old 06-21-2020, 09:26 PM   #10
dmaxweb
dmaxweb's Avatar
So the question remains. Without being able to remove the button sleeve, where does the felt washer go?
Old 06-22-2020, 05:54 AM   #11
David R.
Well the button sleeve definitely is made integral with my ‘30 lever. When I disassembled there was a small hard fiber washer under the spring and the tiniest remnants of a felt washer. I think I did it wrong. I shoved the felt in from bottom side with a wire. I believe it has to go in from top somehow but hole seems too small?
