01-11-2020, 03:53 PM | #1 |
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
brake pedal return spring mounting
My fairly new to me '31 Tudor brake pedal does not return to the full off brake position such that the rear brake lamps stay lit unless I pull the pedal up with my foot while driving. I replaced the spring with a new one where the original one was mounted but no difference.
My car has the Float-A-Motor engine mounts and the spring is currently mounted between the brake pedal arm and the lower mount stud for the Float-A-Motor mounts. It doesn't pull the pedal off in a straight line now and I suspect that is part of the problem. My car also has the mid-eighties F-150 Ford 4 speed trans if that matters. So, my basic question is there advice on where to hook the brake pedal return spring to the trans/chassis etc of the car? Thanks! |
01-11-2020, 06:55 PM | #2 |
Re: brake pedal return spring mounting
Do all your brake rods have proper return springs mounted correctly?
www.whidbeymodelaclub.com |
01-11-2020, 09:34 PM | #3 |
Gary, I would hope so but have not looked into that yet as was not aware that could be an underlying cause.
01-12-2020, 01:52 AM | #4 |
I had the same problem after I installed float a motor mounts in my 30 Victoria. I made a small bracket out of 1/8 flat stock, drilled 2 holes in it, one for the bolt that goes thru the float mount, the other, a small one, to attach the return to. Works great!
01-12-2020, 09:24 AM | #5 |
Did the exact same thing on my 30 coupe, works great, no lingering stop lights.
01-12-2020, 11:18 AM | #6 |
01-14-2020, 07:07 AM | #7 |
Snyders has an after market brake pedal return spring that hooks onto the brake pedal and to the square hole in the rear motor mount (A-2455ACC @ $5.50. Installs very quickly. Note that it does increase the braking pressure. Ed
