Old 10-27-2021, 06:55 AM   #21
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Tire Rotation
Here's a do it yourself tire balancing technique for the Model "A":
File Type: jpg Wheel Balancing Technique On Car 186kb.jpg (60.1 KB, 156 views)
Bob Bidonde
Old 10-27-2021, 10:17 AM   #22
katy
katy's Avatar
[QUOTE=nkaminar;2070625What about the rears wearing faster than the fronts?[/QUOTE]
That's normal.
Old 10-27-2021, 04:15 PM   #23
arnhemmer
My tires wear faster in the rear then the front. It's probably our driving habits. I think it is a good sign that your front alignment and suspension is in decent shape if there is less wear then the rear.
arnhemmer is offline   Reply With Quote
Old 10-27-2021, 05:10 PM   #24
nkaminar
nkaminar's Avatar
Thank you all for your response. I have some radials on order and am anxiously awaiting their arrival. Just my imagination but it seems they are shipped by ox cart. I intend to balance using the method Bob showed. I have done this before with good results. Results depends on if the unbalance is in a plane or a dynamic unbalance. Driving the car will answer the question.
Old 10-27-2021, 05:13 PM   #25
Gene F
Gene F's Avatar
Originally Posted by Gary WA View Post
I do front/ back, back to front- but are they balanced?
OK, where do I get one of those Walter shifter knobs?
Gene F is offline   Reply With Quote
Old 10-27-2021, 08:10 PM   #26
GPierce
GPierce's Avatar
Originally Posted by shew01 View Post
How did you get them into the tire? One glass bead at a time?
I stuck a piece of clear vinyl tubing about a foot long over the valve stem.
Filled it with the beads and vibrated it by putting this sander next to the tube and watched them flow into the tube.
Took maybe 10 minutes per tire.
https://www.harborfreight.com/2-amp-...4aAsaAEALw_wcB
GPierce is offline   Reply With Quote
Old 10-27-2021, 09:48 PM   #27
Synchro909
Synchro909's Avatar
I do basically the same thing. I made a balancing stand out of an old hub and used bearings. I set it so they run free. Once I have located the heavy spot (6 O'clock), I tape a weight to the top of the tyre and try again. Once balanced, I stick that weight to the rim. It doesn't take long to learn to estimate how much weight is needed by how the wheel moves as the heavy spot goes tot he bottom.
I have had wheels I have balanced this way up to about 100 Kph (60+mph) with absolutely no sign of vibration. That's enough for me.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 10-28-2021, 05:47 AM   #28
mercman from oz
mercman from oz's Avatar
Here's a do it yourself tire balancing technique for the Model "A" - from Bob Bidonde
Old 10-29-2021, 09:42 AM   #29
Patrick L.
Patrick L.'s Avatar
When just rotating 4 tires, just X them.
Always leaving radial tires one the same side has now become an old wives tale. True at one time but no longer.
Balancing them is the same as any other vehicle. I put them on the spin balancer and mount the weights on the inside.
Old 10-29-2021, 07:02 PM   #30
Ayers1
Ayers1's Avatar
Originally Posted by nkaminar View Post
Thanks for the comments about the radials. Much appreciated.
What about the rears wearing faster than the fronts? Have you seen this too? Or is just the way I am driving?
Sounds like too many burn outs!!!
I have always heard bias tires get crossed and radials stay on same side. This comes from my service station days of the 70s.
Ayers1 is offline   Reply With Quote
Old 10-31-2021, 03:08 PM   #31
eagle
eagle's Avatar
The powered tires typically wear quicker, unless the alignment is off, then that will cut tires very quickly.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 10-31-2021, 03:24 PM   #32
nkaminar
nkaminar's Avatar
I balanced the wheels/tires as Merc Man outlined. However I noticed that the hub with brake drum was rotating on its own. I stuck 1.5 ounces of weights on the drum to balance it, equivalent to 3/4 ounce at the wheel rim.
So, even with perfectly balanced wheels they could still be out of balance if the drums are not balanced. I seem to remember steel weights spot welded to brake drums in the past.
The stick on weights will not stay on the drum so they got removed. So the wheel on that corner is 3/4 ounce out of balance. I drove the car and did not notice it.
