05-07-2019, 06:50 AM | #1 |
Float a Mount
I have a Hobby member that would like me to install float a mount kit in his Model A. This has a slightly modified 4 cylinder engine with Ranger truck transmission with 4th being overdrive. The rear of trans is mounted with a couple of brackets solid to the cross member. I have read the thread on F.A.M mounts and agree they would help cut down on vibration. I believe the trans is supported because of the way the adapter is mounted between the bell and the trans. What are your thoughts? Thanks, Tom
05-07-2019, 11:30 AM | #2 |
Re: Float a Mount
