Old 10-23-2021, 10:58 PM   #1
Barnwood
Default Looking for photo of a stop light switch installed in a 31.
My dad is looking for a photo of a stop light switch installed in a 31 Model A. I would appreciate if anyone had a photo they would be willing to share.
We can find photos of the part isolated, but not installed.
Barnwood is offline   Reply With Quote
Old 10-23-2021, 11:26 PM   #2
40-A Twins
40-A Twins's Avatar
Default Re: Looking for photo of a stop light switch installed in a 31.
This is the diagram from Service Bulletins. Switch mounts to frame center cross member. Look for 3 holes in line with the brake pedal. 2 of these holes will match the hole pattern on the switch, and center hole is for the plunger to protrude through. The brake pedal to cross shaft has a round flat foot on the end which the switch plunger bumps up against. When the brake pedal is depressed, the plunger can move forward and circuit is closed.
40-A Twins is offline   Reply With Quote
Old 10-24-2021, 10:20 AM   #3
Big hammer
The electrical screws are towards running board, I just installed one, twisted and turned it until it fit. Under the car on your back ain't much fun, oh by the way...... I used a stick to push the brake pedal down and hold it away from the switch, found that out after crawling out from under the car umpteenth time
get a bigger hammer tap done
Old 10-24-2021, 06:49 PM   #4
Barnwood
Thank you, both.
Old 10-24-2021, 10:25 PM   #5
Barnwood
Is this the Service Bulletin you are referring to? https://www.amazon.com/Model-Ford-Se...=UTF8&qid=&sr=
Old 10-24-2021, 10:28 PM   #6
mercman from oz
mercman from oz's Avatar
This is the diagram from Service Bulletin as Posted by 40-A Twins
Old 10-25-2021, 12:15 PM   #7
40-A Twins
40-A Twins's Avatar
Yes this is the complete book of Service Bulletins https://www.amazon.com/Model-Ford-Se...=UTF8&qid=&sr=
Another helpful guide is the Model A Restoration Guidelines and Judging Standards which is very helpful even if you are not restoring your car for show. Without this book I would have never figured out which wiper motor was correct for my 31 coupe.
https://www.mafca.com/cart/index.php?productID=115
Old 10-25-2021, 02:12 PM   #8
alexiskai
alexiskai's Avatar
Just piping up to remind everyone that you can get the Service Bulletins as a searchable PDF file. Also nice to be able to zoom in on the text, for those of us with older eyes.
Old 10-25-2021, 04:25 PM   #9
California Travieso
Send a message via Yahoo to California Travieso
Where do you get the PDF version? The MAFCA site has the hard copy.
David Serrano
California Travieso is offline   Reply With Quote
Old 10-25-2021, 04:35 PM   #10
Russell Reay
Here are pics of the switch on my 1930
Russell Reay is offline   Reply With Quote
Old 10-25-2021, 05:51 PM   #11
alexiskai
alexiskai's Avatar
David Serrano
https://www.ecklers.com/service-bull...7-68631-1.html
