03-30-2024, 10:05 AM | #1 |
hole on dash 42 pickup
[IMG]4644[/IMG] Does anyone know what hole is for over top of starter button Thanks Ted
03-30-2024, 12:08 PM | #2 |
Re: hole on dash 42 pickup
03-30-2024, 02:53 PM | #3 |
Ted, I don't believe that is a factory hole.
03-30-2024, 04:37 PM | #4 |
Suspect added switch for fogs, tec. Nice looking dash. Hope the car is equal. Suspect Pillips head screw is not correct.
03-30-2024, 05:28 PM | #5 |
I've seen it on two other trucks only 42 tho
03-30-2024, 05:30 PM | #6 |
03-30-2024, 05:37 PM | #7 |
Looks like maybe a screw between the speedo and wiper knob. Could be a small grommet. Is yours a 122" wb tonner pickup? Seems the 60 mph speedometer usually in a tonner.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-30-2024, 05:39 PM | #8 |
Ted, is this a big truck or simply a half ton PU?
03-30-2024, 08:13 PM | #9 |
one ton
03-30-2024, 09:37 PM | #10 |
I have had a number of one tons and haven't seen that hole. Maybe about the size of a cigarette lighter? That would be my guess. How 'bout some pictures of this truck?
03-30-2024, 10:24 PM | #11 |
My 47 Tonner pickup has a hole there about 1/3 that size, no idea what it was for.....
03-30-2024, 10:42 PM | #12 |
03-30-2024, 11:11 PM | #13 |
Looks like a nice one! What part of the country is that? Do you have the rear fenders?
03-30-2024, 11:57 PM | #14 |
03-31-2024, 08:24 AM | #15 |
Hi Ted,
I had a 42 1/2 ton for my first Ford. It was X military. It had the same hole same place and same size. My column lock was trashed so I put a aftermarket ign. switch in it. That's on nice and very rare truck. Those die cast ford emblems on the hood are priceless, one year only and it was a short year do to the war. Nobody to my knowledge is or has ever reproduced them. Hope to see and hear more about it. Tim |
03-31-2024, 08:29 AM | #16 |
Picked it up in Alberta Canada it is now in British Columbia And yes i have rear fenders It had been sitting in a barn for 40 years
03-31-2024, 08:56 AM | #17 |
The 1/2 ton I had that same hole and it was a cigarette lighter and there was an under dash ash tray as well .
