Old 07-29-2021, 07:07 AM   #1
Veeder
Default 3 speed stock transmission
Easy question I'm rebuilding and will store the transmission for an extended period of time.
Question with the assumption that all the gears are soaked with oil does anyone see an issues with coating all of the surfaces using a spray lithium lubricant? Just as some added protection?
Veeder is offline   Reply With Quote
Old 07-29-2021, 07:52 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 3 speed stock transmission
I like Fluid Film for keeping corrosion away from metal parts, it’s the only thing that keeps my battery terminals clean.
Old 07-29-2021, 09:46 AM   #3
Ggmac
Ive had issues with spray lithium in south Florida. I use fluid film or CRC soft seal or spray cosmoline for long term
Old 07-29-2021, 10:06 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
If it is in an indoor location that isn't humid, I see no issue with just putting some good gear oil in it, making sure all the gears are coated and calling it good. I've had transmissions that sat for 30 years - no issues in the least when I pulled the covers.
Old 07-29-2021, 10:37 AM   #5
Veeder
Thks guys
Old 07-29-2021, 02:10 PM   #6
Tim Ayers
Michael from Third Gen turned me on to this product. I've used another similar CRC product, but this one was better.
https://www.amazon.com/CRC-06026-Hea.../dp/B0000AXYA0
