Old 03-04-2023, 11:51 PM   #1
Rusty30roadster
Default Split wishbone, pitman inference
Split my bones and installed drop axle, running a stock steering box, how do I cure pitman arm interference? I’ve got a standard and shortened arm, both are bad. Can I bend it outboard to clear the bone? Any advice not involving a diff steering box? Thnx
File Type: jpg 02D83777-B23B-4BA9-8386-EEEA567D68A0.jpg (55.9 KB, 108 views)
File Type: jpg B284B0CB-9B0E-4BDD-9471-FD66C4947FD2.jpg (55.5 KB, 101 views)
Rusty30roadster is offline   Reply With Quote
Old 03-05-2023, 12:33 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Split wishbone, pitman inference
I'm not a Model A guy, buy there are Pitman arms with the ball on the inside, toward the center of the car. That'll get the drag link away from that wishbone. In fact, is it possible to turn your Pitman arm around, if it is sitting on a SQUARE shaft?
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 03-05-2023, 11:13 AM   #3
tinkirk
tinkirk's Avatar
i used a long pitman arm and bent it two different ways to go around the bone, it works for me but then again i'm using hex bar with heim joints on all my steering i cut the ball off the arm drilled and tapped for a 5/8 fine thread bolt works great.
Terry
tinkirk is offline   Reply With Quote
Old 03-05-2023, 12:44 PM   #4
Bob C
Maybe if you turned the pitman arm around like it originally was it would clear.
Old 03-05-2023, 12:44 PM   #5
Rusty30roadster
Terry
Could you share a photo of your bends showing the arm clearance please?
Old 03-05-2023, 12:48 PM   #6
Rusty30roadster
I’ll investigate this today in the garage. Thanks.
Old 03-05-2023, 01:28 PM   #7
tinkirk
tinkirk's Avatar
I will try later today
Terry
Old 03-05-2023, 02:17 PM   #8
rotorwrench
rotorwrench's Avatar
Why not mount the radius rod inboard of the frame mount? Or place the mount inboard on the frame.
These set ups don't do a real good job of replacing the wishbone.
Old 03-05-2023, 03:39 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Good one Bob...
Old 03-05-2023, 06:02 PM   #10
tinkirk
tinkirk's Avatar
Heres one
Old 03-05-2023, 06:04 PM   #11
tinkirk
tinkirk's Avatar
Old 03-05-2023, 07:51 PM   #12
jimvette59
jimvette59's Avatar
YUP turn it around and you may want to bend the steering arm down a bit.
jimvette59 is offline   Reply With Quote
Old 03-06-2023, 02:36 AM   #13
Rusty30roadster
Thanks
Old 03-06-2023, 02:36 AM   #14
Rusty30roadster
Thank you. Photos are very helpful
