Old 08-18-2021, 11:03 PM   #1
Digger
Digger's Avatar
Default Converting to modern 6V coil
OK, I have done this a few times but can’t remember how to do it in the kit I bought doesn’t have distructions. How does the wiring go with the modern coil?
Any layman‘s terms and photos would be helpful, as I’m not a screwmatic kind of guy, my three window would run great the first time around, but when you shut it off after the first run, it would not start again, so the thought was the coil, original, was getting overheated.
File Type: jpg 2FA0D09E-8186-43B2-946B-CBEB41BD17EB.jpg (76.6 KB, 480 views)
File Type: jpg ADAFC31D-C341-49BB-A34F-3288CA0F4F80.jpg (55.1 KB, 114 views)
Digger is offline   Reply With Quote
Old 08-18-2021, 11:55 PM   #2
Brian
Brian's Avatar
Default Re: Converting to modern 6V coil
The [red] wire that currently [pun] connects to the original coil will go the the neg terminal on your new coil, run another wire from + side of coil to that stud on the adapter plate, which also accommodates the wire from condenser. Run an HT lead from new coil to the receptacle in centre of your adapter plate.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 08-18-2021, 11:57 PM   #3
Brian
Brian's Avatar
Depending on your 'new' coil, if you still experience hot start issues, bypass the original resister under the dash
Old 08-19-2021, 12:31 AM   #4
Ken/Alabama
Ken/Alabama's Avatar
Just have the original coil rebuilt and be done with it.
Ken/Alabama is offline   Reply With Quote
Old 08-19-2021, 01:06 AM   #5
koates
If the original coil is being overheated then has it got the original resistor under the dash still connected. If the resistor is not in the coil circuit then the coil will be overheated. Dont know why you guys mess with those adapter plates. The original coil on top of the distributor is the best setup. That coupe of yours is very nice and therefore should have all of the original equipment on it. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-19-2021, 03:17 AM   #6
V8COOPMAN
V8COOPMAN's Avatar
Yo, Digger ....These are actually TWO different cars, aren't they? If so, I love the look of this new one just as much as the first one, although I know how 'special' that first one was! You gonna give us some details on the one you're currently finishing-up? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-19-2021, 08:51 AM   #7
Tim Ayers
Those skirts look killer!
Old 08-19-2021, 11:30 AM   #8
corvette8n
corvette8n's Avatar
Here are some directions I found with the one that was on my car when I bought it.
File Type: jpg 602D3CB6-C949-4D5B-B9F2-7D7ECD53D1E9.jpg (19.7 KB, 34 views)
File Type: jpg 161B9212-2D3B-49DB-B4A2-640B5E9FE839.jpg (18.7 KB, 57 views)
Old 08-19-2021, 11:39 AM   #9
JSeery
JSeery's Avatar
The can coils should not be used with the original resister. They do not require a ballast resistor.
Old 08-19-2021, 10:53 PM   #10
Brian
Brian's Avatar
Agreed, however, I believe the points will last longer with the reduced primary voltage
Old 08-20-2021, 02:40 PM   #11
Kube
Kube's Avatar
This is not necessarily true. Some, but not all "can" type coils have an internal resistor.
Old 08-20-2021, 02:41 PM   #12
Kube
Kube's Avatar
Yep.
Old 08-20-2021, 09:15 PM   #13
Digger
Digger's Avatar
…I was so close to a test fire….over tightened the nut on the cap stud, it snapped off…had to order another kit…see ya next week
File Type: jpg 1FA7F558-FE13-4346-8F5A-53CE225809CE.jpg (75.5 KB, 303 views)
Old 08-20-2021, 09:38 PM   #14
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 08-21-2021, 11:34 AM   #15
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Send your original coil to Skip Haney to have it rebuilt and updated. Problem solved forever.
Tim Carlig
dean333 is offline   Reply With Quote
Old 09-19-2021, 05:48 PM   #16
Digger
Digger's Avatar
Finally getting a chance to follow up on this. So more than one thing can be true. The modern 6 volt coil with adapter cap works great, and I also sent the original to Skip. Swapped back to that, and it also works great.
Both times went on a 30 minute nonstop drive up and down hills etc., got back to the barn, shut it off, start right back up, and both times it started instantly. The other thing that was causing the coils to overheat was as I found out (before the test drives) the radiator was nearly bone dry! So I added some coolant and water, definitely running much better now…
And one tip, but I’m sure everybody knows but just as a reminder, anytime you’re tightening down something that has a brass stud, go very gentle, especially if it’s an original piece over 80 years old. I busted off the stud on the starter switch under the dash, and also busted one off the adapter cap, had to buy another one
Old 09-22-2021, 10:30 AM   #17
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Save some time and trouble , throw away the kit condensor znd replace with a RR175 from Napa
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
