Old 12-02-2021, 06:48 AM   #1
Randy Lausch
Default Diamond block
I have a diamond motor complete I don’t know any thang about it it what is it worth I would like to trade it for a cowl in good shape
Randy Lausch is offline   Reply With Quote
Old 12-02-2021, 12:58 PM   #2
Jim Brierley
Default Re: Diamond block
Diamond blocks are merely blocks made after normal production ceased. they are a bit newer, had hard seats in the exhaust but not much, if anything, else. Value? Maybe a bit more than a production block but not much.
Old 12-02-2021, 02:02 PM   #3
Gary WA
Gary WA's Avatar
Location and what cowl?
www.whidbeymodelaclub.com
Old 12-02-2021, 03:50 PM   #4
Randy Lausch
I’m in mi by the Indiana line. The cowl doesn’t matter because I’m just making a doodle bug.
Old 12-05-2021, 11:50 PM   #5
fredski53
fredski53's Avatar
Randy, I don’t have a cowl to trade, but would you consider selling the block? Thanks, Fred
fredski53 is offline   Reply With Quote
Old 12-06-2021, 01:32 AM   #6
lrf
I had a Diamond block (Aug 1936) with a bad center main, sold just the block for $100. With the cost to rebuild, I was happy with the money and the buyer was happy also. I did keep the miced standard crank though. Drive your "A". LRF
lrf is offline   Reply With Quote
Old 12-06-2021, 12:50 PM   #7
Randy Lausch
Yea if it’s in good shape. If you’re interested call me 2695915334
Old 12-06-2021, 12:58 PM   #8
40-A Twins
40-A Twins's Avatar
Diamond block should have a "B" cam in it.
40-A Twins is offline   Reply With Quote
Old 12-06-2021, 02:54 PM   #9
Chris Haynes
Chris Haynes's Avatar
Originally Posted by lrf View Post
I did keep the miced standard crank though. LRF
What is a Miced crank?
1921 Runabout
1930 Tudor
Early 1930 AA
Old 12-06-2021, 04:05 PM   #10
eagle
eagle's Avatar
Probably means Mic'd ??? Measured with a micrometer.
Old 12-06-2021, 11:02 PM   #11
lrf
Yep, I missed spelled "miced, miked, mic'd, I should of spelled it out. I'm just proud of myself being able to read a micrometer. Drive your "A". LRF
