Old 08-24-2020, 08:35 PM   #1
Shelbycsx
Default Purchased a K R Wilson combination machine
Just picked it up today local in South Jersey. I know it's missing a few items. I believe it has the original electric motor.
Shelbycsx is offline   Reply With Quote
Old 08-24-2020, 08:39 PM   #2
Shelbycsx
Default Re: Purchased a K R Wilson combination machine
I don't know what this is for.
Old 08-24-2020, 08:40 PM   #3
redmodelt
redmodelt's Avatar
The poring fixture in middle 2ed picture is Hempy Cooper. Cool find, lets see the combination machine. Thats a sea lion, used for checking straightness of rods. I don't see the piece that the rods mount too in the box.
Old 08-24-2020, 08:55 PM   #4
Shelbycsx
I'll get a machine pic tomorrow.
Old 08-25-2020, 04:47 AM   #5
Wick
Wick's Avatar
Heck of a find! I've never seen the box before.
Wick is offline   Reply With Quote
Old 08-25-2020, 10:00 AM   #6
stevests
stevests's Avatar
Spectacular find ! I've seen catalog photos but that's the "real deal" !
Here's a similar machine (Stevens) I have for checking connecting rods.
stevests is offline   Reply With Quote
Old 08-25-2020, 10:11 AM   #7
jetmek
Nice acquisition.
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 08-25-2020, 04:40 PM   #8
Shelbycsx
It looks like the table and bed plates have original paint.
Old 08-26-2020, 12:48 AM   #9
KR500
KR500's Avatar
Shelby, there are photos of all the combination machine components in the K.R. Wilson catalogs on www.fordtoolcollector.org website
KR500 is offline   Reply With Quote
Old 08-26-2020, 01:38 AM   #10
McMimmcs
McMimmcs's Avatar
A very valuable acquisition. Congratulations.
Old 08-27-2020, 09:29 AM   #11
hop up
hop up's Avatar
Very cool congratulations
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 08-27-2020, 09:38 AM   #12
jimvette59
jimvette59's Avatar
Museum quality.
jimvette59 is online now   Reply With Quote
Old 08-27-2020, 03:59 PM   #13
McMimmcs
McMimmcs's Avatar
Showing my ignorance, please tell us uninformed what the purpose of this machine.
Old 08-28-2020, 08:54 AM   #14
redmodelt
redmodelt's Avatar
It was used to bore the cylinders or babbitt mains. The box also contains the tools used to pour the mains.
Old 08-29-2020, 12:28 PM   #15
Kevin in NJ
The only catch is it was all designed to use new Ford parts. So you needed a new crank and new rods. Things we do not have today.
The mains can be done by modifying the boring bar to an adjustable cutter. Or you can just make the boring bar and reamer like .020 undersized and get all the cranks cut to that size.
The cylinder boring parts requires a block with the ridge still there and the bottom of the cylinder close to std. The centering jigs needed these to be factory to properly center. If they have been cut then all bets are off. So they are of limited use.
The oil groove tools and the rear main facing tools are very functional. Along with the pouring molds and peening tool. So some tools in the kit are more decorations and others are very very functional and should be used.
A little aside. If you read the catalog you will find the babbitt pot burner is special. It looks different then other burners you find and that is because it need to be hotter. To do the babbitt right it needs to melt fast and be kept fairly hot (when doing proper Ford babbitt mix).
Old 08-30-2020, 05:13 PM   #16
Shelbycsx
Found the serial number 302 this is an early one. I know they made at least 3000 of these. This was made for model t's so you have to use the 1/8th inch riser plates for the A. Anyone else have an earlier serial number
Old 08-31-2020, 05:28 PM   #17
stevests
stevests's Avatar
My table is #594.
Old 08-31-2020, 09:35 PM   #18
700rpm
700rpm's Avatar
You can get a good reprint of a KRW catalog from The Model A Ford Works in Portland, OR. Contact redmodelt here on the forum.
Ray Horton, Portland, OR
