10-17-2021, 03:19 PM | #1 |
50 merc heater bypass
Getting my merc back together for some fall cruising before winter hits. Im bypassing the heater cores and I’m wondering if I can just plug the fittings on the head and water pump or if I have to have a hose running between the two? Looks like I can just plug them, but I want to make sure.
10-17-2021, 03:26 PM | #2 |
Re: 50 merc heater bypass
Plug 'em and get crusing before the snow flies.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
10-17-2021, 05:20 PM | #3 |
I use antiseize compound on the threads. Use brass plugs. Don't over tighten.
10-17-2021, 11:15 PM | #4 |
Thanks guys, I appreciate it.
10-18-2021, 08:52 AM | #5 |
The system on the 50 and 51 cars has a flow control valve that is controlled by the dash control lever but they can deteriorate and need either rebuild or replacement. Last edited by rotorwrench; 10-18-2021 at 08:57 AM. |
