Old 10-17-2021, 07:39 AM   #1
fundytides
fundytides's Avatar
Default Wiper problem 31 Roadster
I have a NORS Trico motor on my 31 Roadster along with an original type blade and arm. The problem is that the wiper blade hits the mounting brackets just before it travels far enough to reverse. This happens on both ends of the travel. I'm thinking of cutting an inch or so off the upper end of the blade but thought I'd ask if anyone has any other solutions. The mounting brackets for the motor are repros.
fundytides is offline   Reply With Quote
Old 10-17-2021, 07:54 AM   #2
gary678*
Default Re: Wiper problem 31 Roadster
Forget the motor except as an ornament. Use Rainex!
gary678* is offline   Reply With Quote
Old 10-17-2021, 08:19 AM   #3
McMimmcs
McMimmcs's Avatar
I couldn’t agree more. Rainex does a great job.
Old 10-17-2021, 08:44 AM   #4
old31
I don't have that issue with my 31 Roadster. can you send a picture of the arm against the bracket?
old31 is offline   Reply With Quote
Old 10-17-2021, 10:25 AM   #5
Bob C
Looking at the Standards it looks like the arm should be 6 3/4" long
and the blade 8 1/4".
Bob C is online now   Reply With Quote
Old 10-17-2021, 10:32 AM   #6
JD 1931
JD 1931's Avatar
my one wiper runs on elbow grease, (manual lever inside)
JD 1931 is offline   Reply With Quote
Old 10-17-2021, 12:13 PM   #7
fundytides
fundytides's Avatar
Good point Bob. I'll check measurements tomorrow
Old 10-19-2021, 10:32 AM   #8
fundytides
fundytides's Avatar
Checked measurement today. They are correct. Any other suggestions outside of shortening the blade on one end?
