02-24-2013, 02:21 PM | #81 |
Re: How many A's still have their original engine.
My 29 Coupe has the original engine.
Tim |
02-24-2013, 05:09 PM | #82 |
One on my two '31 pickups has the original engine, 1st rebuild was last year.
02-24-2013, 06:19 PM | #83 |
The number on my engine block matches the one on my title, so I would say "yes" on my 1930 Coupe. I have not seen the frame numbers yet. My car also has a gasoline ration sticker on the windshield, dated 1942.
02-24-2013, 06:38 PM | #84 |
Donvito, you need the 1930-1 water outlet, as it's about an inch taller than the 1928-9 outlet you have on the engine now. Notice the top hose doesn't fit quite as straight as it could.
02-24-2013, 07:52 PM | #85 |
Tom, thank you. I didn't know that. However, I got my James Rupert water pump this week. I installed the pump yesterday, and finished the job today. I also put a new radiator in the car. The old pump was a nightmare to separate from the head. It took about an hour to loosen it. My aluminum two blade fan broke, trying to get it off from the old pump, so I had to use a four blade fan that I picked up this week. I got everything back together and the hood lines up very nice. I drove the car this afternoon, not one drop of water leaking anywhere. I did not remove the water outlet while installing the water pump and radiator. I've read how the water outlets can break while working with them too. I think I will leave that water outlet alone for now.
