10-21-2022, 04:04 AM | #1 |
lubricating brake components?
Should one use a particular type of grease for the wedges, rollers, pins, pull-off springs etc ?
10-21-2022, 04:23 AM | #2 |
Re: lubricating brake components?
High melting point, same as for wheel bearings.
10-21-2022, 07:48 AM | #3 |
I think most grease that mentions wheels should be rated to at least 500°F. Has anyone ever has their brakes over 300 - 350°F?
Regards Bill |
10-21-2022, 08:08 AM | #4 |
Why not use a product designed for moving brake parts ??
Lubriplate No.110 Brake Lube |
10-22-2022, 03:18 AM | #5 |
I use a molybdenum based dry lube. molybond 122L. Because it is a dry lube, brake dust etc doesn't stick to it. I also use the same lubricant between my leaf springs.
10-22-2022, 04:03 AM | #6 |
SAJ in NZ |
10-24-2022, 11:47 AM | #7 |
+1 on the molybond
10-24-2022, 01:00 PM | #8 |
I don't like using a 'wet' lubricant in brake or other uses where brake dust or dirt can stick to it.
In these situations I use Slip Plate dry graphite. https://www.amazon.com/dp/B005ESITFQ...refix=slip+pla |
10-24-2022, 03:40 PM | #9 |
Thanks for the info. Obviously different countries have different items available and different trade names but following your recommendations I have found "Sealey Bentone grease for brakes" over here that claims to be "Anti-seize bentone (copper-free) grease. suitable for extreme heat applications including brakes and wheel bearings.Water-resistant. Wide temperature range...". probably makes tea as well...should do the trick.
