Old 12-31-2019, 11:16 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Ways to Start With Obstructed Hand Crank
I had to have a tool box between the front frame rails of my 190A because I do some out-of-state traveling each year. I chose the rectangular tool box because it holds more stuff than the the curved box.
Installing a tool box between the frame rails blocks access to hand-crank-start the engine. So given this disadvantage, and the starter fails to work, how could the engine be hand-cranked to start?
The tool box I speak of is attached to its mounting bracket with 4 screws, so it is removable. It's a good idea to use cage nuts or other captive type nuts to facilitate roadside removal. However it's a pain to empty my filled-to-the-brim tool box especially if the weather is inclement.
Another simple modification would be to add access holes through the tool box to accommodate a lengthened hand-crank. Plastic push-in caps would seal the holes in the box. This will be my solution because it minimizes the stuff I will need to take out of the tool box.
Bob Bidonde
Old 12-31-2019, 11:36 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Ways to Start With Obstructed Hand Crank
Always park on hill
Old 12-31-2019, 12:41 PM   #3
super flat
super flat's Avatar
Put a piece of tubing all the way through your tool box and extend the hand crank.
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 12-31-2019, 12:58 PM   #4
Patrick L.
Patrick L.'s Avatar
Originally Posted by Kurt in NJ View Post
Always park on hill
LOL ! Just like owning an old Harley.
Old 12-31-2019, 01:05 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
This would work, get a V8 crank
Old 12-31-2019, 07:17 PM   #6
Big hammer
Always park on hill
Push it to a hill ! 50 years ago I was pushing it a lot.
get a bigger hammer tap done
Old 12-31-2019, 07:38 PM   #7
Charlie Stephens
Bob,
Your car looks great and I assume it has a good battery. I wouldn't expect a problem, and wouldn't waste my time preparing for a problem that might never occur. In rare case of a problem, look for a couple of friends for a push, or call AAA for a jump. Or remove the box on the road for that rare occurance.
Charlie Stephens
Old 12-31-2019, 09:02 PM   #8
Ruth
Wow Bob! That is a BIG Bax. It appears you could just drill a hole in the back for the crank, remove all you stuff and crank the engine with the crank INSIDE the box!
Old 12-31-2019, 09:09 PM   #9
jm29henry
jm29henry's Avatar
Look at Snyder catalog they sell a special wrench it may help you
jm29henry is offline   Reply With Quote
Old 12-31-2019, 10:30 PM   #10
TerryH
TerryH's Avatar
I have had two A’s over a long time period and never needed or used a crank....
TerryH is offline   Reply With Quote
Old 01-01-2020, 01:20 AM   #11
The Master Cylinder
The Master Cylinder's Avatar
I don't think I would try to start an engine with Snyder's "Special Wrench".
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is online now   Reply With Quote
Old 01-01-2020, 03:30 AM   #12
cpf240
cpf240's Avatar
Carry a pull-start rope from a lawn mower. Wrap it around the crank pulley and give it a strong yank!
cpf240 is offline   Reply With Quote
Old 01-01-2020, 10:22 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
I would prefer not to block the crank hole . My repro tool pouch holds everything that I feel that I might need and easily fits under the seat .
Old 01-01-2020, 11:44 AM   #14
Jim/GA
Jim/GA's Avatar
I've seldom had a starting problem in the many years of driving a Model A. Twice, I think, in 30 years. Starter bendix jammed once, starter brushes wore out the other time.
In both cases I did a push start, popping the clutch with the transmission in 2nd gear, and the engine was running after the car was pushed about 10 feet. You enlist the aid of 2 or 3 people who gently push you and you pop the clutch. Off you go!
Much safer than hand cranking an engine that may kick back.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 01-01-2020, 05:14 PM   #15
Purdy Swoft
If its a sedan, make sure that the friends push by the rear bumper instead of the rear body panels ! There is too much risk of bending when the car is pushed by the rear body panels .
