09-18-2013, 12:27 PM | #1 |
Please identify thread
I need to re-new the vacuum pipe nipple which screws into the distributor body. Can any Barners identify the thread please? It looks like 3/8x24, or 1/8th NPT, but neither seems quite right.
Much appreciated, Tom. |
09-18-2013, 12:58 PM | #2 |
Re: Please identify thread
I know that this doesn't help much, but it is the same as the wiper motor fitting on the intake.
09-18-2013, 01:04 PM | #3 |
Tom, I think it's 3/8 UNF. (28 tpi is it?) I'm pretty sure I've put a brake pipe fitting in there before now. The correct fitting is a short brass fitting with a sort of tapered olive.
Mart. Edit: Just went up the garage and a 3/8 UNF bolt screws in nicely. 3/8 UNF is 28tpi - I checked that too. Last edited by Mart; 09-18-2013 at 05:18 PM. |
09-18-2013, 04:11 PM | #4 |
tom, i believe the correct name for the fitting in question is "double compression nut", i can`t verify the size and thread count. btw, this is the other Tom Walker.
tom |
09-18-2013, 04:24 PM | #5 |
It's 3/8 - 24 for certain. The fitting was a special compression type made exclusively for Ford.
09-18-2013, 05:25 PM | #6 |
Are the fittings available? Mart. |
09-18-2013, 05:39 PM | #7 |
Here is a link to an outfit that has those type fittings.
http://www.fastfittings.com/double-comp-fittings |
09-18-2013, 05:42 PM | #8 |
Thanks guys, I will make one out of an old bolt.
09-19-2013, 01:20 AM | #9 |
Rots of ruck.
