Old 03-31-2017, 07:29 AM   #1
jwilliams81
jwilliams81's Avatar
Default Why not a full steel roof?
As a relatively new A owner, I have been curious as to why they don't have a full steel roof.
Knowing what I do about Henry, I am guessing it was a cost issue?
1931 Murray Town Sedan. Black body with Apple Green pin stripe.
1923 Model T Touring with electric start. Low radiator
Cincinnati, Ohio
jwilliams81 is offline   Reply With Quote
Old 03-31-2017, 07:37 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Why not a full steel roof?
I think it was a stamping issue along with the long seams needed to be finished----along with the traditional body methof of nailing to a woof frame----Ford was working to remove the wood by 31, the pickup had a steel roof, the slant window sedan lost it's structural wood mostly---think of the length of the seams to be welded, filled and leaded, I have a 53 Citroen, it's desige dates to early 30s, there is still the ring of reinforced metal where the cloth went, the top stamping was welded in and seams filled with lead, but you can see that not all the seams were "seamless", there are some transitions that don't quite match the unbroken contours of a one piece roof intergrated into the design
Kurt in NJ is online now   Reply With Quote
Old 03-31-2017, 07:38 AM   #3
SeaSlugs
SeaSlugs's Avatar
i was told while we've had the presses big enough at the time the mills couldn't supply and transport steel in wide enough sheets to be able to stamp out a roof.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-31-2017, 08:17 AM   #4
2manycars
2manycars's Avatar
I have heard that also, but the stamping for the side of a tudor takes a pretty big panel, bigger than the roof for a coupe would need. Even the back of a tudor or fordor is a bigger panel than would be needed for a coupe top. I think it was just an evolution of the early closed bodies, which were made like the carriages of not long before. Look at the body of a model T sedan, and you will see that it was flat, with the sides of the body ending at the top in a sharp corner, with the top attached at the edge.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 03-31-2017, 08:50 AM   #5
JRShaw
JRShaw's Avatar
Smile Re: Why not a full steel roof?
I have read and seen articles that besides any sheet metal width or die capabilities, the technology for that deep of a draw did not exist at that time (early 1930's). The latest Model "A" News letter (January-February 2017) has mention of a full steel top Victoria on page #26. I am not sure if this would be a stamped insert of an appropriate size (my guess) -or- a truly fully stamped body with a metal roof. Ford did not come out with that until 1937.
JRShaw is offline   Reply With Quote
Old 03-31-2017, 09:03 AM   #6
John Stone
John Stone's Avatar
Model A's flex so much that the top would just crack at the seams. I've seen hot rods that tops were welded and cracked.
John Stone is offline   Reply With Quote
Old 03-31-2017, 09:41 AM   #7
Hicktick
Hicktick's Avatar
Ever ride in a tin can ??? The noise would be loud .
Sometimes I want to say ,,You should have bought a Shay.
Hicktick is offline   Reply With Quote
Old 03-31-2017, 10:11 AM   #8
Kevin in NJ
Ford wanted an all steel roof as it would be MUCH cheaper to build. Technology or design did not quite have the ability to make the structure.
Consider the slant sedans. They did a full change over by May of 31 when they were not far off from a design change to the 32's. The labor costs of building the wood bodied fordors was significant enough to warrant the change. The slants had wood blocks for interior mounting and then the wood for the top.
The reason for the switch to the more expensive stainless was labor costs to do the plating.
Remember this was the guy who hired a company to analyze all the plant operations to see if they could change things to reduce costs of manufacture.
Old 03-31-2017, 12:59 PM   #9
CHuDWah
CHuDWah's Avatar
Most, if not all, non-Ford manufacturers also used non-steel roofs. If Ford, or any of the others, could have made all-steel roofs, they likely would have because it would have been a significant selling point over the competition. 1937 seems to be the year most changed to solid roofs. Was there some technological breakthrough then?
CHuDWah is offline   Reply With Quote
Old 03-31-2017, 01:42 PM   #10
Will N
Will N's Avatar
Just my own conjecture, but I don't think the size of the presses or the sheet metal was the limiting factor. I'm with Hicktick. The styling of the roofs back in the Model A era was a flat plane. Flat metal has no rigidity, and would likely tend to drum as the car moved. Tin can! It wasn't until the styling changed to add curvature and thus rigidity to the roof that full metal was used.
Will N is offline   Reply With Quote
Old 03-31-2017, 01:55 PM   #11
mshmodela
mshmodela's Avatar
Roof kept water out... just like the non-steel roof on most homes...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-31-2017, 02:00 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I once rented a Ford Taurus, with a flat "plastic" section in the roof. At 82 MPH, it would drum you out of the car & I couldn't even HEAR the RADIO!
Bill Huh?
"THE ASSISTANT GURU OF STUFF"
Old 03-31-2017, 04:34 PM   #13
Chippy Minton
In Britain the 1950's Ford Angela's, Populars and Prefects had cloth panels in their roofs. There must still have been some advantage then, long after the potential problem of pressing would have been sorted out.
Chippy Minton is offline   Reply With Quote
Old 03-31-2017, 04:47 PM   #14
redmodelt
redmodelt's Avatar
RE; I have read and seen articles that besides any sheet metal width or die capabilities, the technology for that deep of a draw did not exist at that time (early 1930's).
In the early years of the Model T's, the rear axle housing was drawn steel so the technology for deep draw was in use. Also think about the Model T crank case.
Old 03-31-2017, 05:20 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
Fabric top means no hail dents.
Old 03-31-2017, 06:47 PM   #16
harryc
I had a tudor back in the 60s that had a steel top attached with metal screws when I got it. I sprayed the underside of the steel panel with undercoating and it made no noise at all
harryc is offline   Reply With Quote
Old 03-31-2017, 07:01 PM   #17
SeaSlugs
SeaSlugs's Avatar
SOunds about like jeep wranglers like 87-2006, plastic hard top sounds like your driving a plastic igloo cooler. soft top sounds like a tent going down the road...
Old 03-31-2017, 10:16 PM   #18
Gold Digger
Back in 1968 and 9 I owned a 28 coupe that someone had put galvanized sheet metal roof in that was soldered all way around. Didn't leak a drop and I can't remember ever hearing any type of noise made from the roof. It didn't have any head liner if that makes a difference.
Gold Digger is offline   Reply With Quote
