04-25-2022, 03:25 AM | #1 |
Victoria Patch panels
Anybody make panels for a Victoria?
Thanks |
04-25-2022, 05:29 AM | #2 |
Re: Victoria Patch panels
Which ones, where on the car?
04-25-2022, 07:55 AM | #3 |
Door bottom and behind rear wheels, it's a 1930.
Thanks |
04-25-2022, 10:49 AM | #4 |
To the best of knowledge…..no. The inner liner of the doors are bad to rust out and….they’re not made either.. aren’t I a bearer of great news!
Cowl and between door and rear fender can be modified for use from others available |
04-25-2022, 10:56 AM | #5 |
Thanks
04-25-2022, 03:18 PM | #6 |
I’m not sure anyone has ever made them…not sure. Correction- Snyders list outside patches for Vic doors Last edited by Oldbluoval; 04-25-2022 at 06:30 PM. |
04-26-2022, 08:40 AM | #7 |
The cowl patch panels work with some tweaking. Otherwise.all of mine were homemade. By the way, Victorias are 1931 cars including those assembled in 1930.
Bob Bidonde |
04-26-2022, 03:22 PM | #8 |
Bob you’re a bigger guru than me on vics but
I’ve seen Vics with 30 shells and boards But never one with the oval dash Ford using up parts I suppose |
04-26-2022, 05:29 PM | #9 |
Look in the swap meet section:
“Parting out Victoria body” W. Michael |
04-26-2022, 06:59 PM | #10 |
Noting how wide the Victoria door is, & If only the outer lower section needs to be replaced can a patch panel from another model be used if extended?
If you are close to a hobbyiest with a bead roller you could have them made for you.,...
Tim Downtown, Ca |
04-26-2022, 07:25 PM | #11 |
Snyder’s lists outer patch. Now whether they’re in stock is another question.
Most stocked door patches for sale are not exactly correct. |
04-27-2022, 10:50 AM | #12 |
The Victoria was the first Model "A" to have what became 1931 features. It was not produced with a 1930 radiator shell.
Bob Bidonde |
