Old 04-07-2014, 02:07 PM   #1
mshmodela
mshmodela's Avatar
Default Key switch left ON
On a somewhat related post, the question came to my mind:
If the key switch on the dash board was left in the "ON" position for long period of time, could this do damage to the coil and or points (or maybe both)... I've not do this thankfully at this point...
Thanks,
-Mike
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 04-07-2014, 02:07 PM   #2
Mitch//pa
Default Re: Key switch left ON
yes
Old 04-07-2014, 02:20 PM   #3
mshmodela
mshmodela's Avatar
OK, my long ago memory working with my Dad on his Ford 8N and our IH tractor was burning out the points... in looking the distributor in the in Les Andrews book, the old thought of those long ago conversation came back.. So... hind the keys from my kiddies... thanks.
Old 04-07-2014, 02:47 PM   #4
Franchise_24
Franchise_24's Avatar
https://fordbarn.com/forum/showthread.php?t=136179
It's being discussed here...
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 04-07-2014, 03:22 PM   #5
jm29henry
jm29henry's Avatar
It just happened to me I put my car away at the beginning of Nov . I ran all of the gas out of the bowl until she stopped ,and I must of got destracted and left the ignition on .I was finally able to check on it last week and found the switch was left on the battery was totally dead .I put a slow 2 amp charge for two day and to my great relief she started right up .I tried again today hopping the battery was still up and it was again she started up and all seems well .THANK GOD!!!
jm29henry is offline   Reply With Quote
Old 04-07-2014, 07:39 PM   #6
glenn in camino
glenn in camino's Avatar
A club member left his key on. In about 1/2 hour, the coil caught fire.
glenn in camino is offline   Reply With Quote
Old 04-07-2014, 10:10 PM   #7
eagle
eagle's Avatar
Was he running 12 volt on a 6 volt coil? Maybe 8 volt battery?
eagle is offline   Reply With Quote
Old 04-07-2014, 10:39 PM   #8
tbirdtbird
"It just happened to me I put my car away at the beginning of Nov . I ran all of the gas out of the bowl until she stopped ,and I must of got destracted and left the ignition on .I was finally able to check on it last week and found the switch was left on the battery was totally dead .I put a slow 2 amp charge for two day and to my great relief she started right up .I tried again today hopping the battery was still up and it was again she started up and all seems well .THANK GOD!!!"
Points were prolly open. Battery would have been dead by now anyway
'31 180A
tbirdtbird is offline   Reply With Quote
Old 04-08-2014, 12:22 AM   #9
Tom maxwell
Tom maxwell's Avatar
How do you leave the key on?When turning the car off , do you......
Choke the car off?
Turn the fuel off?
Stall the car?
I turn the key off to turn the car off.
Tom maxwell is offline   Reply With Quote
Old 04-08-2014, 12:59 AM   #10
Y-Blockhead
Y-Blockhead's Avatar
Choke the car off?
Turn the fuel off?
Stall the car?
Originally Posted by tbirdtbird View Post
" I ran all of the gas out of the bowl until she stopped…"
I think he already answered your question… But I, like you, turn the key off AND then I take the key with me.
Old 04-08-2014, 06:10 AM   #11
Tom F OHIO
Tom F OHIO's Avatar
In the garage not only do I take the key out and turn the gas off but I pull the main fuse just for safety reasons.
Tom F OHIO is offline   Reply With Quote
Old 04-08-2014, 06:14 AM   #12
Mitch//pa
i always turn the kill under the seat whenever i turn off the motor.
even for a brief stop
Old 04-08-2014, 06:33 AM   #13
Franchise_24
Yeah as of late I have been taking the fuse out as well. I once left my blinkers turned on and didn't realize till about 3 weeks later and not only did it drain the battery, it drained it so much it wouldn't recharge, so when I shut it off, take the key and pull the fuse to avoid any future problems.
Old 04-08-2014, 08:00 AM   #14
jkcrosson
jkcrosson's Avatar
Choke the car off?
Turn the fuel off?
Stall the car?
I had turned the gas off and ran the gas out. Not thinking, I told my Dad, who is not familiar with popout switches to turn the switch off. He turned the key, pulled it out but did not push in the popout.
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 04-08-2014, 01:44 PM   #15
rons49
rons49's Avatar
When putting the car away in my garage, I have been in habit of running the fuel out. Then, I press in the popout, then off with the battery "kill" switch and finally I hang the keys on the gas shut off valve. I have an indented firewall.
rons49 is offline   Reply With Quote
Old 04-08-2014, 03:49 PM   #16
mshmodela
mshmodela's Avatar
Nice. so you turn off the fuel valve --let it run out of gas... As for indented firewall (Late 31') Do you have a carburetor with a bulb on it? I have a 30' engine and two fuel value (org. 31' on the engine side of the firewall and another make-shift one half way down... both work (my guess is why this was done but it's the way i got my 31'
Old 04-08-2014, 04:53 PM   #17
Spokes
A fellow member of our local Model A Club left his key on. When he went back to start the car, his coil had melted down all over his engine. It was a Great learning experience. Replaced the coil and the engine started right up.
Spokes is offline   Reply With Quote
