07-16-2019, 12:04 PM | #1 |
C3 A/T Tool Set
City:
Dexter
State:
MI
Price:
$50.00
Ford/Rotunda factory transmission service set T74P-7700-A for the 1974 on up Ford C3 automatic transmission. Set is in excellent condition, but is missing three tools: the long reach wrench for loosening the cooler line fittings in the chassis, the neutral safety switch socket, and two trans mounting adapter bolts. Does have all the necessary tools to overhaul a C3 properly, including the very important selective sized tools for properly lining up the front pump to the converter housing. Unlike aftermarket kits that only have one size adaptor, this kit contains four different sizes to insure the pump is lined up correctly. This kit could also be used on the later A4LD four speed overdrive units as they were designed off the C3. 16 piece set.
Last edited by flatheadron; 07-16-2019 at 12:22 PM. Reason: Added more description |
10-19-2019, 10:19 AM | #2 |
Re: C3 A/T Tool Set
