Old 10-04-2021, 04:12 PM   #1
DMMuir
Default 40 tudor replacement quarter glass
Where is my best source?
Or can I remove the existing cracked but functioning window and have it locally cut somewhere?
I think I heard that the quarter glass is the same on both sides, is that correct?
DMMuir is offline   Reply With Quote
Old 10-04-2021, 05:20 PM   #2
woodiewagon46
Default Re: 40 tudor replacement quarter glass
Any good glass shop can supply the glass. The "Bugs" are available from Third Generation Automotive. Both sides are the same.
woodiewagon46 is offline   Reply With Quote
Old 10-04-2021, 11:40 PM   #3
DMMuir
Bugs?
Old 10-05-2021, 08:44 AM   #4
woodiewagon46
The "Bugs" are the Ford oval and date code that is etched in the original glass.
Old 10-05-2021, 11:21 AM   #5
19Fordy
19Fordy's Avatar
Here's a bug example.
https://www.google.com/search?q=ford...0ksdDWBsmeI3yM
Old 10-05-2021, 11:40 AM   #6
marko39
Pay close attention as where the glass sits in the channel. If new glass is not exactly positioned as the old, problems will arise when installed to regulator.
marko39 is offline   Reply With Quote
Old 10-05-2021, 11:34 PM   #7
DMMuir
This could be an issue. the glass on the drivers side is currently "floating" in the door.
Old 10-05-2021, 11:48 PM   #8
DMMuir
Originally Posted by 19Fordy View Post
So buying 1 bug would let me etch all the glass? or one per etching?
Old 10-07-2021, 07:47 PM   #9
TJ
TJ's Avatar
Call the vendor who sells the "bugs", but most likely you need to use one "bug" per glass.
