Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 01-23-2016, 06:53 PM   #1
1917modelt
Send a message via MSN to 1917modelt
Default in the beginning
what tools or measuring devices did henry ford used when first manufacturing the model T ?
were micrometers in existence then ?
when one looks at the massive repeatability of the assembly line back in his days and even as he done with his R&D ...
iam sure henry used some form of a micrometer to make sure things fit.
1917modelt is offline   Reply With Quote
Old 01-23-2016, 07:26 PM   #2
tinman080
tinman080's Avatar
Default Re: in the beginning
The Ford plants were known for their fantastic machines and machining capabilities. The flathead V/8 was actually machined on a lower unit cost than the prior 4cylinder engines. Multi-machining operations at once were the norm at Ford. Leland at Cadillac and Lincoln was known for precise machining at the dawn of the 20th century. so rest assured machine tools and measuring tools to make and set them up were readily available.
Just Passin' Thru.....Slowly!
tinman080 is offline   Reply With Quote
Old 01-24-2016, 04:05 PM   #3
1917modelt
when henry made his first automobile in his garage, i would be curious what measuring tools he used.
and how he was able to keep such tight tolerances ?
just asking .....
