Old 10-06-2014, 07:30 PM   #21
Mitch//pa
Default Re: torque specs for front u-bolts
Originally Posted by Tom Wesenberg View Post
Whoa..........did a Studebaker run over your foot?
Mike gave a good reply. I like to tighten them good and tight with the weight on the springs, then drive it a few blocks and over a couple bumps, then recheck the tightness and install the cotter pins. Do the same for the rear spring.
Lol
and also good advice as usual
Old 10-06-2014, 09:20 PM   #22
Bruskie
Come on now lets play nicely
Bruskie is offline   Reply With Quote
Old 10-06-2014, 09:29 PM   #23
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by Fred View Post
AT TIMES ?? You mean like NOW !!
Sorry I'm OFFENSIVE to you, Fred. ----Fred, why don't you just take the liberty to BLOCK my posts & "PROBLEM SOLVED"! It just takes a quick click!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-06-2014, 10:07 PM   #24
Purdy Swoft
Purdy Swoft's Avatar
The way that the U bolts are tightened can effect the level of the car .
Old 10-06-2014, 10:09 PM   #25
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
Well Gentlemen , I have learned how not to post my feeling on this site from now on I will just read and learn from you. Thank you and good nite! Don in N. W. In.
Indiana A. Lover is offline   Reply With Quote
Old 10-07-2014, 03:06 PM   #26
bobH
In my opinion, one of the best observations here. Also not noted, how the brakes are affected. An example... had a car on which the brakes ALWAYS pulled. Dogged this problem for a very long time, couple/three years. Eventually changed front brakes completely, backing plates complete, and drums. STILL pulled. Bottom line, eventually tried running with front spring u-bolts VERY loose, and brake pulling majically disappeared. So, we snugged up the front u-bolts to 'pretty-snug', and cotter-keyed them. Brakes have never pulled since, and car sits 'pretty-level'. IMO, 'awful-damn-tight' on those u-bolts, is a bad idea. Give it some room to 'work'. (And, wasn't there, originally, a piece of flexible webbing-like material between the spring and the frame, further allowing a little 'wiggle'? These pads are listed in vendor catalogs for 32-up. Not sure if they apply to A's.)
JMO
bobH is offline   Reply With Quote
Old 10-15-2014, 02:29 PM   #27
Clinton
Clinton's Avatar
I'd like to thank all you guys for spending the time to answer my question. I will tighten them good and tight but not to the point of braking them. I was concerned about the piece of anti-squeak material that was suggested to me to put between the spring and the cross member, never did that before, so I guess I better keep and eye on the bolts until the material flattens out and the spring will stay stable. Any of you guys use that anti-squeak between your springs? Thanks again guys.
Clinton
PS Well after reading JMO's post I will be even more careful, thanks JMO and all.
Clinton is offline   Reply With Quote
