Old 05-14-2012, 08:47 AM   #1
Jim Parker Toronto
Jim Parker Toronto's Avatar
Default Brake Lights
Finally got Ol' Blue, 30 Fordor, out of storage on Friday, and went to our Annual Inspection Day with the club on Saturday. The car failed the inspection because the brake lights would not come on. In checking the wiring, both tail lights work, (the signals come on) so the wiring and bulbs are ok there. My third brake light in the rear window works, so I assume the brake switch is doing its job as well. My question is, could there be something wrong in the signal switch, that would stop the lights from working? The wire comes off the brake light switch, and goes into the signal body, and then back to the tail lights. Has anyone had a similar problem? Thanks for any help.... Jim
Jim Parker Toronto is offline   Reply With Quote
Old 05-14-2012, 09:11 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Brake Lights
Yes, it is possible that the problem is in the turn signal switch if they are combined with the brake lights.
This is the prime reason I would keep the signals a seperate system and wiring harness from the factory lights. I think problems are less likely, and if a problem comes up, it's easier to check if it's a seperate system.
Old 05-14-2012, 12:49 PM   #3
Jim Parker Toronto
Thanks Tom, I suspected that.
Old 05-14-2012, 01:33 PM   #4
V4F
V4F's Avatar
i use hand signals , never interferes with any thing ........... sorry it just came out !
V4f
V4F is offline   Reply With Quote
Old 05-14-2012, 04:23 PM   #5
Muttley
Muttley's Avatar
Originally Posted by steve norcal View Post
I use hand signals, never interferes with anything ...........sorry it just came out!
Plus you have the added benefit of the "freeway finger" with hand signals that you just dont get with the electronic versions.
Muttley is offline   Reply With Quote
Old 05-15-2012, 06:05 AM   #6
dave in australia
Would that be the version for 'turning left', 'turning right' and 'turning nasty'.
dave in australia is offline   Reply With Quote
