09-30-2020, 06:54 PM | #1 |
Carburetor backfire
I have a 31 three window four-door with a B motor the car runs great up until 45 miles an hour anything over 45 it starts to pop through the carburetor any suggestions would be grateful. Carburetor adjustment? Timing adjustment? fuel mixture adjustment? drive the car off a cliff ?? Lol
Thanks again Daba 31 three window four-door deluxe with B motor 31 slant window four-door deluxe |
09-30-2020, 08:39 PM | #2 |
Re: Carburetor backfire
I would check point gap setting to be sure that there is enough dwell angle to allow coil to build back it's field.
As point rubbing block wears, the points ride closer to the cam, holding them open too long. Then as speed increases, you get to a point where the points are not closed long enough to build up a full field in the coil. A weak spark results. |
09-30-2020, 10:34 PM | #3 |
It sounds lean to me. Have you opened up the GAV when it starts popping to see if it runs a little better? Be sure to let us know what the solution is.
Have you played with the timing recently? |
10-01-2020, 12:45 AM | #4 |
I would guess lean mixture as Chuck Sea/Tac said or timing is off for that engine rpm and load.
I recently had a Porsche ( I know way different beast hear me out though) that had some surging and backfiring problems at cruising speed . I ended up finding the intake valves way too tight and a series of small vacuum leaks. Adjusting the valves cleared up a lot of issue and fixing the vacuum leaks cleared up the rest. |
10-01-2020, 03:06 AM | #5 |
yep often a symptom of a weak mixture/fuel starvation, ... so easy things first ... check the flow of fuel from tank to carb and the various stariners filters etc.. then move on to other stuff.
10-01-2020, 06:22 AM | #6 |
10-01-2020, 06:46 AM | #7 |
It sounds like it is time to get that 'B' carburetor cleaned out.
10-01-2020, 06:52 AM | #8 |
Good info, but, loosen the fuel cap and take it for a drive. The vents are known to plug.
10-01-2020, 08:36 AM | #9 |
Intake valve hanging up try MMO in the gas tank.
10-01-2020, 11:06 AM | #10 |
10-01-2020, 11:58 AM | #11 |
10-01-2020, 03:37 PM | #12 |
I tried the gav no difference then the timing much worse. I used the New timing wrench I got for the model a apparently the timing is slightly different. It moved about a quarter of a turn more than it was to start I think I’m going to go back to that point and try again.
10-01-2020, 06:08 PM | #13 |
I opened up the points and BINGO it did the trick. Thanks again for all your suggestions.
Daba |
10-01-2020, 09:25 PM | #14 |
Glad to see that fixed it for you.
George |
10-02-2020, 03:28 PM | #15 |
Carburetor backfire
