Old 09-06-2021, 02:39 PM   #1
Utopia Texas
Utopia Texas's Avatar
Default Four Post Lift Recommendations….
Any current thoughts on four post lifts for a Model A? Good or bad experiences? Getting too old to crawl on the floor though the ‘31 sits up pretty high. Any decent brands that have installation available?
Utopia Texas is offline   Reply With Quote
Old 09-06-2021, 03:56 PM   #2
jayvee34
jayvee34's Avatar
Default Re: Four Post Lift Recommendations….
Bought my Back Yard Buddy 4 post lift 25 plus years ago. I use it most every day
and have 0 problems with it. Made in the USA, claims to be the safest lift made.
IMO it is quality made. I installed it.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 09-06-2021, 03:56 PM   #3
[email protected]
modela@aol.com's Avatar
4 posts better than 2…..
modela@aol.com is offline   Reply With Quote
Old 09-06-2021, 04:04 PM   #4
Keith True
Keith True's Avatar
Am I really seeing one inch of concrete under that lift? Nothing on that lift gave way, that one was the floor under it. A garage here in town has gotten many years out of his Mohawk lifts.
Old 09-06-2021, 04:38 PM   #5
trulyvintage
trulyvintage's Avatar
Lightbulb Re: Four Post Lift Recommendations….
Did you post over on the MTFCA Forum ?
Freight is expensive - buy one close.
Don’t buy used.
Hire someone with experience to install it.
Jim
trulyvintage is offline   Reply With Quote
Old 09-06-2021, 04:40 PM   #6
griffin
Look at Advantage lifts. Good quality. Very happy with mine.
griffin is offline   Reply With Quote
Old 09-06-2021, 05:39 PM   #7
51504bat
51504bat's Avatar
Almost every shop in town use Bend Pak lifts, both 2 and 4 post. that tells me something.
Old 09-06-2021, 06:46 PM   #8
holdover
I have 2 Bendpacs, use them most every day, 13 yrs no problems. My HD 12 has a trolley jack that allows me to pick-up the front or rear. I have no need for a 2 post. If you are mechanically inclined you can install it yourself. Directions are good. I did both of mine alone with a floor jack and some jack stands. The HD 9 can be mobile or bolted down, the HD 12/14 need to be bolted down, due to one ramp being adjustable for width.
holdover is offline   Reply With Quote
Old 09-06-2021, 07:16 PM   #9
wwirz
I have a 4 post lift. I have put all my vehicles up on it including a tractor. Mine has locks (as I believe most do) to prevent it coming down due to loss of hydraulic pressure. I love mine.
wwirz is offline   Reply With Quote
Old 09-07-2021, 08:53 AM   #10
Pat/Ohio
Pat/Ohio's Avatar
Advantage Lifts has purchased Backyard Buddy. The Backyard Buddy is still made in America with U.S. or Canadian steel. I have had mine for nearly 20 years with no problems. Installed it myself.
https://www.advantagelifts.com/pages...rd-buddy-lifts
Stay Safe,
Pat
Pat/Ohio is offline   Reply With Quote
Old 09-07-2021, 09:35 AM   #11
griffin
2 other things to consider when looking at buying a lift...
1. Do you have a slab with a minimum of 4" thickness? For most lift manufacturers, 4" is the minimum with quite a few preferring 6".
2. What is the height of the area where you are looking to install the lift. Be sure you have enough room to raise the lift WITH the car on top. Nothing like raising a car to find the car roof to building ceiling has a conflict of trying to share the same space.
As far as installation. There is a guy out of Waller that is on the approved assemblers list for Advantage.
Old 09-07-2021, 09:35 AM   #12
katy
katy's Avatar
My 4 post is not fastened down and is very stable, in fact it came w/a set of 4 casters, (easy to put on and remove) for moving it around if needed. There is holes for fastening it down if desired.
Old 09-07-2021, 11:59 AM   #13
Bruce of MN
Bruce of MN's Avatar
You may have to modify your garage door to hug the ceiling rather than retract to the usual same elevation as the opening header.
Old 09-08-2021, 10:30 AM   #14
redmodelt
redmodelt's Avatar
https://www.fordbarn.com/forum/showthread.php?p=1990506
https://www.fordbarn.com/forum/showt...4343&showall=1
Old 09-08-2021, 06:46 PM   #15
TravisDM
Good to hear about the recommendation for Advantage lifts. My uncle is looking to get a 4-post lift soon after finished installing the suspension from 4Wheelonline onto the truck and start renovating the garage.
TravisDM is offline   Reply With Quote
Old 09-08-2021, 09:05 PM   #16
[email protected]
Originally Posted by [email protected] View Post
Attachment 472321
More ammo….
https://carbuzz.com/news/watch-and-c...-tips-off-lift
Old 09-08-2021, 09:50 PM   #17
Chris Haynes
Chris Haynes's Avatar
With a 4 post how do you adjust brakes? Repack wheel bearings? Do suspension work? Rotate tires? A 2 post lift is your best option.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-08-2021, 10:00 PM   #18
mercman from oz
mercman from oz's Avatar
Ouch - not good!!!
Old 09-09-2021, 08:00 AM   #19
griffin
Air over hydraulic jack bridge mounted between the runners. Or for the unfortunates, a plain jack in the plain bridge.
Old 09-09-2021, 08:47 AM   #20
51504bat
51504bat's Avatar
See post number 8 regarding a trolley jack.
