Old 09-05-2021, 04:51 PM   #1
russcc
Default Stuck engine after fuel pump failure
I am usually on the EV8 forum, and this engine problem may be a little to late model for this forum, but maybe the members have a solution. '74 Ford 351 Windsor engine. The engine ran great up to the point the fuel pump failed. We replaced it, and tried to restart the engine, but it turned over very slow as if the battery was low. The battery was fine, we loaded tested it. Checked the oil and and found it was overfilled/ We realized when the fuel pump failed it leaked gas into the oil pan. We changed the oil & filter, and it wouldn't turn over with the starter or by hand. Suggestions ? Thank you.
russcc is offline   Reply With Quote
Old 09-05-2021, 05:14 PM   #2
KULTULZ
KULTULZ's Avatar
Unhappy Re: Stuck engine after fuel pump failure
As long as the pump was installed correctly and she still won't turn over ...
Did you remove the plugs and try? Sounds like a tear down.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-05-2021, 06:27 PM   #3
dmsfrr
dmsfrr's Avatar
Default Re: Stuck engine after fuel pump failure
I'd suspect badly galled main and rod bearings, and the crank won't be any better.
dmsfrr is offline   Reply With Quote
Old 09-06-2021, 06:14 AM   #4
russcc
Fuel pump. Don't know that much about the 351 Windsor. I am EV8 guy. How is the fuel pump driven, off a camshaft lobe or a push rod ? We have the plugs out and shot MMO in the cylinders. Any other tips for freeing u the engine before we pull the pan ? Thank you.
Old 09-06-2021, 06:34 AM   #5
cadillac512
cadillac512's Avatar
Hate to say it, but it sure sounds like it had enough fuel in the oil to do what dmsfrr said: damage one or more bearings on the crank. Even if you get it to turn it is likely going to fail shortly and hurt more parts. Best to drop the pan and start pulling rod and main bearing caps...
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-06-2021, 07:43 AM   #6
KULTULZ
KULTULZ's Avatar
Post Re: Stuck engine after fuel pump failure
It is driven off an eccentric bolted to the front of the cam. Just for my curiosity, remove the pump and see if she turns by hand.
If she won't, you will need a crankcase kit (cheapest way out).
- WHY IS IT ... -
Old 09-06-2021, 08:01 AM   #7
russcc
Thank you. What is a crankcase kit ?
Old 09-06-2021, 08:36 AM   #8
KULTULZ
KULTULZ's Avatar
Exclamation Re: Stuck engine after fuel pump failure
You know, that is a very good question. It is a term used by a CRS impaired senior.
The correct term is CRANKSHAFT KIT. It is a re-manufactured (turned) crank fitted with bearings in a box.
And I just had another hot flash - (and it wasn't an errant gas bubble) ..
Gasoline in a crankcase can be ignited by a misfire or errant spark. Crank by hand only until properly diagnosed and drained/refilled.
- WHY IS IT ... -
Old 09-06-2021, 01:09 PM   #9
russcc
Already drained & changed the oil. Took out about 2 gallons of oil & gas.
Old 09-06-2021, 04:47 PM   #10
JSeery
JSeery's Avatar
Not sure how bad a Windsor is about it, but I have seen SBCs just about fill the crankcase with fuel. Most of my Windsors have been FI, except back beyond my memory span!
Old 09-06-2021, 04:57 PM   #11
Daves55Sedan
Daves55Sedan's Avatar
Take the new fuel pump back off and try to crank the engine. If the engine now turns over normally, you had the wrong pump installed or there is something wrong with that new pump. You didn't install the pump upside down, did ya?
Daves55Sedan is offline   Reply With Quote
