Old 04-23-2024, 07:41 PM   #1
sportcoupeman
Default engine compression levels.
What is the correct cylinder compression reading on a standard 40 hp Ford engine. What would be normal on a 40-year-old rebuilt engine? I'm getting 52lbs on all 4 cylinders. Any input out there?
sportcoupeman is offline   Reply With Quote
Old 04-23-2024, 10:01 PM   #2
bruceincam
bruceincam's Avatar
Default Re: engine compression levels.
Stock compression ratio was 4.2:1. So --- 90 some years later, not accounting for any rebuilds, you look about right. What's particularly good is that all cylinders are the same. That's rare and that's great. I'll say you have nothing to worry about. By the way, 4.2 at sea level would be around 62 PSI.
bruceincam is offline   Reply With Quote
Old 04-24-2024, 09:25 AM   #3
old31
52 is pretty good.
If you have a standard head the math would be:
4.2x14.7. About 60 lbs on a new engine.
Some say the formula should be 4.2x14.7+14.7.
old31 is offline   Reply With Quote
Old 04-24-2024, 09:32 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Compression Tests are not really a good indicator. Worn rings with cylinders filled with oil can equal those numbers, -or more. What you need to do is perform a cylinder leakage test and then a contribution test.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-24-2024, 09:39 AM   #5
alexiskai
alexiskai's Avatar
Isn't a contribution test used to isolate a single bad cylinder? It wouldn't really tell you if all the cylinders were equally worn.
Old 04-24-2024, 09:56 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
Absolute compression pressure = (4.22x14.7)+14.7.
Gauge compression Pressure = 4.22x14.7.
We work with gauges. Scientists work with absolute pressure.
Bob Bidonde
Old 04-24-2024, 10:12 AM   #7
Bob Bidonde
My rule of thumb is that Model A & Model B engines with stock cylinder heads will run well on compression gauge readings as ow as 50 psig, and no more than a 5 psig difference between cylinders.
By the way, boring an engine increases its compression ratio a bit.
Bob Bidonde
Old 04-24-2024, 10:56 AM   #8
Fullraceflathead
Fullraceflathead's Avatar
My engine has been sleeve back to the original bore size and has the original 4.2 compression head my compression readings are basically 60-65 on all 4 cylinders.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-24-2024, 01:44 PM   #9
BRENT in 10-uh-C
Actually, it generally tells quite a bit. When used in conjunction with a sensitive RPM gauge, it can help diagnose items like a worn cylinder(s), or too lean fuel mixture, or leaking manifold, etc. as it points you to the faulty areas to check mechanical items. If each cylinder dropped the RPMs by 25% when cancelled, that would indicate all 4 cylinders are pretty even. If #1 and #4 RPMs drop by 30% but #2 & #3 only drop by 20%
BRENT in 10-uh-C
Old 04-25-2024, 09:15 AM   #10
katy
katy's Avatar
And then?
Old 04-27-2024, 11:41 AM   #11
alexiskai
alexiskai's Avatar
Here’s an example of a device that could be used to do contribution testing.
