07-25-2021, 04:24 PM | #1 |
Oil splatter ??
IMG_3538[1].jpg This is on the garage floor .
07-25-2021, 04:43 PM | #2 |
Re: Oil splatter ??
from exhaust?
www.whidbeymodelaclub.com |
07-25-2021, 04:54 PM | #3 |
Re: Oil splatter ??
Yes from exhaust . Oil and water levels are fine
07-25-2021, 05:34 PM | #4 |
Re: Oil splatter ??
Running a little rich or choked it a little too long.
07-25-2021, 05:37 PM | #5 |
Re: Oil splatter ??
How to thin it out . It runs good for being an old engine
07-25-2021, 06:05 PM | #6 |
Re: Oil splatter ??
Dave / Lincoln Nebraska |
07-25-2021, 06:42 PM | #7 |
Re: Oil splatter ??
Moisture in the system. Only at start up after setting a week or so
07-25-2021, 07:09 PM | #8 |
Re: Oil splatter ??
Mine do the same. I start my A's once a week for 20 min each. and drive as much as I can. Nothing to worry about! Also in a heated garage!
07-25-2021, 09:15 PM | #9 |
Re: Oil splatter ??
Thanks to all for your input. It happens only at start-up once in a while. Fluids stay in say zones .
07-26-2021, 04:17 AM | #10 |
Re: Oil splatter ??
Hi Jerry,
this is due to the fact that the combustion gases condense in the cold exhaust during a cold start. Water forms with soot. That squirts out of the tailpipe. This is normal with every cold start. When the exhaust (and engine) is hot, the exhaust gases come out of the exhaust as steam.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
07-26-2021, 05:01 AM | #11 |
Re: Oil splatter ??
Thanks to all for the input. It is only at start up .
