Old 07-11-2020, 04:10 PM   #1
L5wolvesf
Default 55 Customline Disc Swap?
Hi all, I may have a line on getting the front disc brakes off of a 69 Galaxie for my 55 Customline. It seems like it was a swap I read about but I can't find it now. Has anyone here done that particular swap? Thank you
1955 Customline 4dr, 292 2bbl, 3sp
L5wolvesf is offline   Reply With Quote
Old 07-11-2020, 08:48 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: 55 Customline Disc Swap?
Never heard of swapping front disc brakes off of 69 Galaxie. The usual swap is done with late '70's Ford Granada or Lincoln Versailles. Not sure what exact years, but others here know.
Daves55Sedan is offline   Reply With Quote
Old 07-12-2020, 10:38 AM   #3
Ole Don
Ole Don's Avatar
As far as I know, any Granada has parts that will bolt on the 55. The lower hole of the spindle needs to be reamed with a tapered ream, and the hubs need to be turned down for the center hole of stock wheels to fit. There was an article in Y Block Magazine about it, back copies may be still available.
Or, email me at [email protected]. I'll see if it is still in me computer.
Ole Don is offline   Reply With Quote
Old 07-12-2020, 04:10 PM   #4
L5wolvesf
The Granada conversion is on my to do list but this came available locally and I thought I had seen that it is an option. It could also be the article/post was regarding and LTD conversion. IIRC the V8 Granada parts are the same up to 1980.
Old 07-12-2020, 04:10 PM   #5
L5wolvesf
If you have it that would be great, I will send you an email. Thank you
Old 07-13-2020, 07:38 PM   #6
L5wolvesf
Thank you Don very good article.
Old 07-13-2020, 11:05 PM   #7
nascardave
Hi Guys, There is a set of granada spindles on e bay. # 373104792330 $215 or B.O.
Hope this helps, Dave
nascardave is offline   Reply With Quote
Old 07-14-2020, 06:02 AM   #8
cvicky
cvicky's Avatar
85 crown vic wheels fit those Granada rotars but its a 15x6" wheel
cvicky is offline   Reply With Quote
Old 07-14-2020, 04:10 PM   #9
nascardave
If anyone needs them I have a set of custom made Granada rotors that were made with the small register so you don't have to cut down original rotors. They were made for a company that was going to do Granada brakes for the early Fords. Brand new in the box, never used $120 for the pair plus shipping.
Also have a number of 15" wheels of large center hole 15"x5 1/2", 15"x 6" , 15"x 6 1/2"
$25 each plus shipping. Dave
