Old 01-05-2020, 06:59 PM   #1
bgalla
Default charge battery via alternator lug
This is a 31 ford stock except for a 12V system with a single wire output Alternator. Can I charge the battery (witch is hard to access) with out harming the diodes by connecting one lead of the charger to the alternator lug and the other to ground? See any problems with that? Negative ground. Thanks
bgalla is offline   Reply With Quote
Old 01-05-2020, 07:11 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: charge battery via alternator lug
Yes, you can do that, if it is a low amp charger (up to 10 amps). You are correct, it is a very easy place to connect to. You can also connect to either of the little wing nuts on the front of the terminal box (on the firewall).
You can also connect the charger clip to the big post on the starter switch where the battery cable connects to the switch. That cable can take all the amps you want to throw at it. But be careful with the clip around the starter switch or it will short out as you connect to the post.
Double check the polarity of the charger alligator clips, compared to the battery install. Don't get it backwards. Stock wiring was positive ground, but your 12 volt car may now be negative ground.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 01-06-2020, 02:31 PM   #3
Jim Brierley
Amen!
Jim Brierley is offline   Reply With Quote
Old 01-06-2020, 05:27 PM   #4
denis4x4
denis4x4's Avatar
You can see the positive post on my remote battery terminals. About $20 a pair at Speedway plus cables. Easy to use jumper cables and trickle chargers
File Type: jpg 97F000D0-D1F8-4738-86F7-C8AB7A15C676.jpg (32.3 KB, 120 views)
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-10-2020, 11:47 AM   #5
bgalla
A little delayed, but thanks all for the reassurance and suggestions. Bruce
Old 01-10-2020, 12:09 PM   #6
Anteek29
Anteek29's Avatar
Interesting wheel cover.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 01-10-2020, 01:24 PM   #7
alexiskai
alexiskai's Avatar
This is awesome, I did not know this was a thing. So I can charge my 6V-pos. ground battery (3A charger) by connecting the red lead to ground and the black lead to that nut on the starter switch? No manual disconnecting of anything required?
Old 01-10-2020, 01:35 PM   #8
katy
katy's Avatar
"that nut on the starter switch" is a direct connection to the battery negative terminal unless there's a disconnect switch in between.
Old 01-10-2020, 02:06 PM   #9
alexiskai
alexiskai's Avatar
I realize that, I mainly wanted to confirm that there's no risk of damage to the electrical components by leaving the normal circuit in place. Previously, if I wanted to charge the battery, I would open the access port in the floorboard, disconnect the ground cable, and connect my charging leads. It would be nice not to have to do that.
Old 01-11-2020, 09:37 AM   #10
eagle
eagle's Avatar
No need to disconnect battery to charge it. The best way to charge any battery is with a trickle charger. 2 amps or less. Leave it on for 24+ hours. Much better for the battery than fast charging. Also, if you have an electronic voltage regulator a fast charger can damage it.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 01-11-2020, 10:15 AM   #11
rotorwrench
rotorwrench's Avatar
That post on the alternator is where the output comes through after it passes through the diode bridge in the alternator. The diodes are generally pretty tough and can hold fast against a back current flow. The bridge is what rectifies the AC current to DC for charging plus it acts like a cut out for back voltage or current. If you connect anywhere on the bus then you are also connecting to all points previously mentioned since they all share the bus circuit. Ground is ground and can be connected to anywhere on the vehicle that is bonded with the frame. A dedicated ground location should be bare metal and be protected with something like silicon grease to keep it from corrosive effects. The starter switch is likely the best place to access the bus circuit and it should be protected against corrosion as well.
If folks have a regular lead acid battery, it should be checked on a regular schedule for electrolyte levels up to par. Take good care of the battery and it will take good care of you.
