Old 10-07-2018, 08:08 AM   #1
Anteek29
Anteek29's Avatar
Default Carb on Stock '55 Vic?
Have a '55 Vic (3 speed OD 272 dual exhaust) coming in. Judging from the round inlet with horizontal crossbar air cleaner, it must have a 4 bbl carb?
OMG - Could it be the infamous towering inferno teapot?
Well, I'll know for sure when the car arrives.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 10-07-2018, 09:05 AM   #2
reman
Default Re: Carb on Stock '55 Vic?
Yep, if it's original, thats what ya got.
reman is offline   Reply With Quote
Old 10-07-2018, 10:05 AM   #3
KULTULZ
KULTULZ's Avatar
Post Re: Carb on Stock '55 Vic?
Don't let the H4000 worry you. Properly setup, it is a good carb, especially if the car is a dedicated resto.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-07-2018, 10:09 AM   #4
scicala
scicala's Avatar
I agree. Don't pay attention to the towering inferno tales. They are only that to people that don't know carburetors, but love old tales.
Good luck with your car when it arrives !
Sal
Old 10-07-2018, 11:38 AM   #5
Anteek29
Anteek29's Avatar
Added another pic of the '55 Vic
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 10-07-2018, 12:08 PM   #6
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Carb on Stock '55 Vic?
Absolutely Beautiful! Is it a survivor or resto?
- WHY IS IT ... -
Old 10-07-2018, 03:14 PM   #7
Anteek29
Anteek29's Avatar
Thanks! Restored
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 10-07-2018, 03:29 PM   #8
texas webb
That's a good looking Ford there.
texas webb is offline   Reply With Quote
Old 10-07-2018, 06:47 PM   #9
KULTULZ
KULTULZ's Avatar
Exclamation Re: Carb on Stock '55 Vic?
Interesting. Where did you hear or learn of this? I have been trying to figure out the horizontal and vertical bars for awhile.
- WHY IS IT ... -
Old 10-07-2018, 06:48 PM   #10
scicala
scicala's Avatar
Beautiful '55 Victoria !
From the picture in post #1, it appears the engine has been updated to a later intake manifold. Appears to be a '56 style (ECZ-A), but more likely a '57 (ECZ-B).
Appears to have original style '55 heads with the core plugs though.
Sal
Old 10-07-2018, 06:51 PM   #11
KULTULZ
KULTULZ's Avatar
Lightbulb Re: Carb on Stock '55 Vic?
Sal
We'll ask him to remove the ACL when he gets it ...
- WHY IS IT ... -
Old 10-07-2018, 09:07 PM   #12
paul2748
paul2748's Avatar
Early 56 heads had the core plugs. Oddly enough, both were "C" heads. And, you must have real goooood eyesight - I really can't see the core plugs in the heads.
The coil mount is the 56-57 mount
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-07-2018, 09:48 PM   #13
scicala
scicala's Avatar
Yes, the early '56 heads still had core plugs. Don't see them very often though. My eyesight isn't that good, but when clicking on the picture to increase the size, I can see the core plug on the pass. side head.
Sal
Old 10-07-2018, 09:53 PM   #14
scicala
scicala's Avatar
From my experience the '55 air cleaners had a horizontal bar at the inlet, and '56 had a vertical bar, and have seen with no bar also for '56. Don't know if one is early or late production. Not sure what the reason is to even have a bar there, except for maybe induction noise ?
Sal
Old 10-07-2018, 11:31 PM   #15
Daves55Sedan
Daves55Sedan's Avatar
That air inlet tip on the air cleaner is a separate stamped steel part that gets pressed onto the air cleaner at the factory. The way the tip should be installed is with the "bar" oriented vertically. The purpose of the bar is to separate the air in the middle of the inlet so it will flow around on the inside of the air-cleaner. But I have seen many of them oriented horizontally. I always called those "factory bloopers".
Daves55Sedan is offline   Reply With Quote
Old 10-07-2018, 11:42 PM   #16
Daves55Sedan
Is that an 8-volt battery??? It is odd to see that this car has the cheaper vacuum type heater control instead of the deluxe type with the thermostatically controlled water valve and bypass hose.
From the photo, the steering wheel appears to be black. In '55, All Fairlane models had the steering wheel painted to match the color of the dashboard and interior garnish mouldings.
Not being picky. I didn't re-paint my interior with the factory colors either.
Old 10-08-2018, 12:19 AM   #17
Anteek29
Anteek29's Avatar
Yes, the battery has 4 cells = 8 volt. At some point I will either revert to the original 6 volts or upgrade to 12 volts.
I have verified the steering wheel is not black but does perfectly match the turquoise interior.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Old 10-08-2018, 01:48 AM   #18
KULTULZ
KULTULZ's Avatar
Sal
OK. Makes sense.
I have photos of either being on either year but being so long ago and parts being swapped may explain it.
- WHY IS IT ... -
Old 10-08-2018, 12:02 PM   #19
scicala
scicala's Avatar
My '55 Mercury I had when a kid had a horizontal bar at the inlet. I know it was the original air cleaner. Have seen more '55's like this than any other way. Same with the vertical bar on the '56.
Sal
Old 10-08-2018, 12:14 PM   #20
Anteek29
Anteek29's Avatar
From my research the air cleaner bars were horizontal for '55, vertical for '56.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
