Old 03-17-2020, 08:46 AM   #21
mike657894
mike657894's Avatar
Default Re: What kind of glue for running board mat?
weld wood needs to dry for 20 mins after being applied liberally to both sides. and needs to be tacky to the touch not wet. I have used it for many things after it was recomended by a jet ski foam company. holds up well to wet situations. IF STUCK TOGETHER WET OR TOO EARLY IT WILL BUBBLE EVERY TIME. It needs to off gas and with rubber on metal or foam on fiberglass it has no where to escape.
mike657894 is offline   Reply With Quote
