Old 11-12-2023, 05:26 PM   #1
expavr
expavr's Avatar
Default What Have We Here?
I started a teardown of a 59 engine taken from a 1945 AF Crash Truck. In the process discovered cracks in 2 locations (photos attached). These locations are on the Left Bank. It was my intention to do a mild performance build: 4" Merc Crank, Edmunds Custom Heads, Edmunds Custom Intake Manifold and 3/4 Cam. QUESTION: Will the location of these cracks be an issue with the intended build? Can they be fixed or dealt with? If so how? Any thoughts will be appreciated. Thanks. Les Williams
expavr is offline   Reply With Quote
Old 11-12-2023, 07:36 PM   #2
petehoovie
petehoovie's Avatar
Default Re: What Have We Here?
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 11-12-2023, 07:50 PM   #3
Shu47
Shu47's Avatar
Those type of cracks are extremely common and not a problem. Cracks to the cylinder wall and valve seats are when you have a problem.
Shu47 is offline   Reply With Quote
Old 11-12-2023, 07:54 PM   #4
ford38v8
ford38v8's Avatar
As cracks go, those are in good locations. You will have an increased likelihood of water seepage at those studs, so be sure to use a good sealant. The unknown is whether you’re going to be able to torque those nuts without widening the cracks. I would say this would be the priority issue to deal with before dropping a wad of money on it.
Alan
Old 11-12-2023, 08:07 PM   #5
T Scott
I think I saw in previous posts that those cracks are so typical that they actually have a Ford part number.
T Scott is offline   Reply With Quote
Old 11-12-2023, 10:12 PM   #6
47topless
47topless's Avatar
So funny! Really cracked me up.
47topless is offline   Reply With Quote
Old 11-13-2023, 10:50 AM   #7
Ol' Ron
Ol' Ron's Avatar
I only torque My heads to 45 ft/lbs in 3 heat cycles, so never gave them a thought!
G
Old 11-13-2023, 06:12 PM   #8
mcflash
Don't skimp on the quality of sealant you use.
mcflash is offline   Reply With Quote
Old 11-13-2023, 06:45 PM   #9
51504bat
51504bat's Avatar
The 8ba in my '39 p/u had several of those Ford part number cracks. Used #2 Permatex on the head bolts per the machinist who built the short block. No issues.
