Old 07-13-2023, 03:30 PM   #21
Gene F
Gene F's Avatar
Default Re: 312 thermostat bypass hose plug question
You actually can make your own shrould...but it takes a little doing. There is a video I recall seeing years ago on youtube. Styrafoam you stack and shape. Then cover if with aluminum foil. Then lay fiberglass on it. After it cures ya pop it out, and spray paint it.
Doesn't look hard, but seems like a trial and error type of thing too. Definately not a 1 afternoon in the garage project.
Gene F is offline   Reply With Quote
Old 07-13-2023, 03:31 PM   #22
Gene F
Gene F's Avatar
FYI, my 57 did not hold a lot of fluid with the factory radiator... I mean like hardly nothing.
Where are you? Does it get schorching hot there?
Old 07-13-2023, 04:08 PM   #23
Abchoppers
Abchoppers's Avatar
I’m on Long Island NY, gets into high 90’s here on some days. When I measure temps before and after the radiator it’s a good drop in temp, sometimes 25-30 degrees. I’m waiting on a high flow thermostat to be delivered, then I’ll investigate more because I have no idea what is in there now.
Abchoppers is offline   Reply With Quote
Old 07-15-2023, 06:58 PM   #24
Abchoppers
Abchoppers's Avatar
So I ended up installing a 160 high flow thermostat after removing a 180 high flow. Drilled a couple of holes in it too. I also added the 3/8” plug into the bypass hose. Turned out to be an easy install with no leaks. Temps are about 10 degrees cooler overall. So far I like the results. Now come winter time I might be changing to a higher stat if I don’t get enough heat, but that’s a problem for another day. Thanks all for the suggestions and ideas
Ryan
