01-06-2016, 11:24 AM | #41 |
Re: Help needed from the electrical experts
Bob, here are two videos that may help you next time you have a problem in this area. jack
https://www.youtube.com/watch?v=eXA6izLrTOc https://www.youtube.com/watch?v=ZbHQ5CyZQ2I |
01-06-2016, 03:12 PM | #42 |
Great news Bob - I also found that the pig tail wire was at fault - the cloth and rubber covering on mine had deteriorated to such an extent at a point where the wire appears to have been bent - that it was shorting across the lower body. Thanks again to all the contributors for helping solve Bob's (and my) problem.
01-07-2016, 10:12 PM | #43 |
This says it all for electrical problems. A lot of hours to find the one little electrical fault. Glad you solved the problem. Now I know why I like metal work.
John Poole |
01-07-2016, 10:56 PM | #44 |
I've had very good luck with the wireless bottom plate (Bratton's 17300) and the acorn nut on the points. Am I asking for problems down the road?
Sewall |
01-07-2016, 11:33 PM | #45 | |
I know owners that have had them for years no problem But I know more that have had problem a year or two down the line.
01-08-2016, 03:58 PM | #46 |
Sewall |
01-08-2016, 04:24 PM | #47 | |
You are better off staying with Henry's design. If you use the proper multi-strand fine wire that Bratton's sell and it is oriented properly it will serve you well for years as it is a positive electrical connection. Tom Endy |
01-08-2016, 08:06 PM | #48 |
01-09-2016, 08:23 PM | #49 |
Years ago, it was NOT uncommon to see a car being towed by 2 MULES or HORSES, (Looked like a "STAGECOACH") or being pushed for miles, by another CAR!
Bill Old
01-10-2016, 09:56 AM | #50 |
Try jumping out the ignition switch l bet I will run!
01-10-2016, 10:17 AM | #51 |
01-10-2016, 01:21 PM | #52 |
Sometimes it's good to READ & RE-READ all the info, before posting a comment.---I've put my FOOT in my MOUTH, several times!!!
Bill W.
01-11-2016, 01:48 AM | #53 |
No, really Bill, you?
