Old 09-25-2011, 01:26 PM   #1
willobs
Default 1926 T Split Rim
Need to replace 3 tubes, no rim spreader, Is it possible to Demount tire to replace tube with wheels mounted. Thanks
willobs is offline   Reply With Quote
Old 09-25-2011, 02:11 PM   #2
Willie in Houston
Willie in Houston's Avatar
Default Re: 1926 T Split Rim
Split rims do not have a drop center. You can not get the tire off the rim without removing the rim from the car. The rim needs to be able to lap over itself at the split.
This reduces the rim size and lets you pull a side of tire off rim and replace the tube.
Willie in Houston is offline   Reply With Quote
Old 09-26-2011, 11:54 AM   #3
willobs
Can this be done with out a rim spreader? Was thinking a Jack? Thanks
Old 09-26-2011, 02:04 PM   #4
Willie in Houston
With the keeper off (the one that locks the rims together), a tire tool or large screwdriver can be used to pry one side of split rim up and on top of the other side. This allows the rim to undersize and lets you do the tube and tire.
Some new tires seem to be a little undersize and then a rim spreader is helpful to push the tire back out where the two sides of the rim butt up at the split. I own a rim spreader, but I rarely use it.
Old 09-26-2011, 02:05 PM   #5
Willie in Houston
I forgot, PLEASE deflate the tire first.
Old 09-26-2011, 04:12 PM   #6
willobs
Willie.
Thanks for the info. Tubes are self deflating.
Old 09-26-2011, 08:54 PM   #7
tmodelman
tmodelman's Avatar
A jack can be used to close the rim.
tmodelman is offline   Reply With Quote
Old 09-27-2011, 11:35 AM   #8
CharlieB
CharlieB's Avatar
Give it a shot Will it might be easier than you think. I did 5 of them on my '27. Didn't need a stretcher or a jack. The image shown by Tmodelman will work fine if necessary.
CharlieB is offline   Reply With Quote
