Old 12-28-2015, 09:46 PM   #1
Arcieri
Arcieri's Avatar
Default Possible discrepancy in Judging Standards
Section 2 page 6 of the RG & JS discusses the position of the ground strap bolt in relation to the battery and cross member. The text reads "the bolt head was located on the battery side of the cross member".
The accompanying picture in the Standards appears to show the opposite. I did a search but couldn't find the answer.
Which way should it be for a judged car ?
Thanks,
Ray
Arcieri is offline   Reply With Quote
Old 12-28-2015, 10:58 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Possible discrepancy in Judging Standards
Bolt head faces the battery. That's how I view the picture.
Old 12-28-2015, 11:05 PM   #3
Mitch//pa
I agree with Tom the pic looks correct
Old 12-28-2015, 11:08 PM   #4
DougVieyra
DougVieyra's Avatar
Bolt head faces the battery. No question in that regard.
DougVieyra is offline   Reply With Quote
Old 12-28-2015, 11:10 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Notice the orientation of the old and new design bolts. The "socket" wrench in on the nut and the open end is on the bolt head. Looks OK.
Old 12-28-2015, 11:11 PM   #6
Bruce Adams
Bruce Adams's Avatar
I'm with Mitch and Tom, looking at the combo wrench on the head and the ratchet on the nut. There is no sign of threads beyond the combo wrench. The bolts shown are also facing left which leans towards indicating that is how they are placed.
Bruce Adams is offline   Reply With Quote
Old 12-28-2015, 11:40 PM   #7
Larry Jenkins
I also think I see a lock washer under the bolt head..
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-29-2015, 12:48 AM   #8
Arcieri
Arcieri's Avatar
I agree that the big picture shows the two bolt heads facing the battery, I guess I was looking more at the fine detail. Not sure where the standards committee pulled the diagram from, but it looks to me like the bolt head is facing the cross member in that diagram.
I think I can see a flat and lock washer facing the battery. I know I am being too anal, but just saying. Anyway, thanks for answering my question and I will face the head to the battery.
Ray
Old 12-29-2015, 01:05 AM   #9
Mike V. Florida
Ray
Nope, don't worry keep them questions coming!
Old 12-29-2015, 02:20 AM   #10
Tom Wesenberg
I just looked up the bolt in my 1931 Parts Price List, and yes, it does list a lock washer and flat washer.
Another thread didn't pass the inspection of the one star general.
I think he's actually a drill sergeant masquerading as a one star general.
Old 12-29-2015, 11:01 AM   #11
MikeK
MikeK's Avatar
Upon close inspection I agree with Arcieri's description in post #8. The drawing definitely shows the socket half-cocked off the hex bolt head and on the outside a flat, then split washer followed by a hex nut.
This makes me wonder whether the change was made to facilitate faster assembly, as a hex can be engaged easier and with more orientations than a single pair of flats, or if the change was to replace a more expensive specialty fastener with a stock bolt. Perhaps both?
Notwithstanding the drawing, it goes in with the head on the outside for fine-point. That does not, of course, mean that every single one that went down the assembly line was put in the same way. I wonder how many original battery cases got dinged by backwards bolts infringing upon the free clearance.
MikeK is offline   Reply With Quote
Old 12-29-2015, 11:14 AM   #12
Jim Mason
Jim Mason's Avatar
The drawing is from the service bulletins
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is online now   Reply With Quote
Old 12-29-2015, 11:29 AM   #13
31Tudor
31Tudor's Avatar
Jim, to clarify this, Bolt, washer? (or not) battery strap, frame cross member, lockwasher, and nut?
31Tudor is offline   Reply With Quote
Old 12-29-2015, 01:07 PM   #14
Joop
Joop's Avatar
If you can see in the picture it is explained how to install.
Joop is offline   Reply With Quote
Old 04-15-2016, 08:03 PM   #15
Arcieri
Arcieri's Avatar
Would like to revisit this one more time as I am getting ready to install the battery for a judged car.
We have established that the bolt head faces the battery per the RG&JS.
Now, how do the flat washer and lock nut figure in this installation??
The picture, which is from the service bulletins (which we mostly accept as fact) shows a flat washer and a lock washer on the battery side of the frame rail.
Is this what the judges accept as correct? Or is the picture incorrect in the
service bulletins?
Should the flat washer and lock washer be on the side of the frame rail opposite the battery behind the nut like we see on about 99% of the usual bolt-nut installations?
Thanks
Ray
Old 04-15-2016, 08:43 PM   #16
RonC
RonC's Avatar
service bulletins?
Thanks
Ray
Read Post 14. Battery, bolt head, lock washer, washer, ground strap, frame, nut.
RonC is offline   Reply With Quote
Old 04-15-2016, 08:48 PM   #17
Arcieri
Arcieri's Avatar
Thanks Ron (and Joop) looks like I will install it that way. Just seemed different than what I was used to.
Ray
Old 04-15-2016, 09:07 PM   #18
RonC
RonC's Avatar
Originally Posted by Timothy Kelly View Post
It seems to me that it would be good to include the ground strap in the sequence. More specifically, the ground strap appears to fit between the frame and the flat washer.
Yes I left that out
Old 04-16-2016, 11:58 AM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"Maybe" the Judges will be too FAT to scoot under your car to check it????
I LOVE that wrench! Can they be bought in a SET? Do they "ratchet"? WHY is the Dog LAFFIN'????
Bill Odd
"THE ASSISTANT GURU OF STUFF"
Old 04-16-2016, 12:25 PM   #20
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Read post 14, makes it pretty clear and good. Take your time. What year is the car your getting ready for Fine Point?
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
