Old 12-26-2013, 02:38 PM   #1
dwertz2000
dwertz2000's Avatar
Default How to read a 1950 F1 VIN Plate off the firewall?
Trying to determine, if possible, the original color of my 1950 F1 pickup from the stampings on the firewall. It reads: 98RC260870 A TL.
Then next to the right of the plate are numbers/letter stamped directly on the firewall 512K1793.
Any help would be apprieciated
THANKS!
dwertz2000 is offline   Reply With Quote
Old 12-26-2013, 03:02 PM   #2
Ralph Moore
Ralph Moore's Avatar
Default Re: How to read a 1950 F1 VIN Plate off the firewall?
If you can pull the vin plate off you may find the orig color under it. When I restored my 45 truck it was the only place I found good paint.
Ralph Moore is offline   Reply With Quote
Old 12-26-2013, 04:02 PM   #3
flatford8
flatford8's Avatar
Keep searching on Google and you will eventually find a site that can break down the VIN. or see if the EFV8 club has an official restoration book......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 12-26-2013, 05:36 PM   #4
kendall
this is whats on my 1949 f1 ..... don't know what it means also.
kendall is offline   Reply With Quote
Old 12-26-2013, 05:59 PM   #5
jdl
jdl's Avatar
Send a message via ICQ to jdl
Here's a link with some colors...might help?
http://www.clubfte.com/users/earl/Re...aterial_2.html
jdl is offline   Reply With Quote
Old 12-26-2013, 07:14 PM   #6
waterboychuck
waterboychuck's Avatar
When I purchased my 48 F1 I found the original color inside the cab and on the firewall. It was grey. Now it's the original red offered in the year. Pick something that you like and go with that.
waterboychuck is offline   Reply With Quote
Old 12-26-2013, 07:34 PM   #7
rotorwrench
rotorwrench's Avatar
Prior to 51, those firewall codes were harder to decipher.
This discussion was a good one. http://www.ford-trucks.com/forums/42...ut-off-47.html
There are a few here on the Barn too. Some of the guys that responded on that forum also respond here as well.
Old 12-26-2013, 07:38 PM   #8
mtflat
mtflat's Avatar
THANKS!
They're pretty easy:
9 - 49 or 50 and your's is close to the cutoff, it was probably a '49 but sold and titled in 50 (if you're sure of the title)
8R - 239 flathead V8
C - half ton pickup
260870 - actual serial number assigned to the truck
ATL - Atlanta assembly plant
Firewall:
5 - Sheridan Blue exterior color
12K - produced October 12, 1949 (at the time Ford was using the calendar year as model year for trucks)
1793 - vehicle down the line (doesn't really have much meaning that we have been able to determine)
Hope this helps!
Tim
mtflat is offline   Reply With Quote
Old 12-27-2013, 12:07 PM   #9
dwertz2000
dwertz2000's Avatar
Yes, Thank you mtflat, helps alot!!
