Old 09-28-2013, 04:25 PM   #1
4tford
4tford's Avatar
Default 4 holley 81's what jetting and power valves
Back to this intake now that I have it in my hands. Yes carbs are HOLLEY 81's. on a 276 flatty for the street what would be the best jetting and power valves to use. No idea what is inside yet. Thanks Bill
4tford is offline   Reply With Quote
Old 09-28-2013, 04:33 PM   #2
ken ct
Default Re: 4 holley 81's what jetting and power valves
I would try all .041 MJ [Stock is .043] PV #3.5 in all. May try pump link in rear hole [not in middle holes] gives a smaller shot. This going to be a crap shoot all around.. Best of luck.I may have all you need?? ken ct.
ken ct is offline   Reply With Quote
Old 09-28-2013, 05:33 PM   #3
rotorwrench
rotorwrench's Avatar
Four carbs is a lot of fuel delivery for a street motor even if they are all 81s. A person can use progressive linkage on three carbs but I don't know if anyone currently makes one for four.
Old 09-28-2013, 05:38 PM   #4
Charlie ny
4t,
With straight linkage....only way to go in my opinion with 4x2's .....your vac
signal will be real low. At the risk of doubting looks from JWL and Ken I'd block the
PV's and tune with main jets. '94's get edgy in a setup like this. My focus is not
theory it is street reliability. EX. my best success with 3x2 94's is to block the end
carb PV's and retain the PV in the center carb only.
I absolutely feel this setup will be happiest with Stromberg 81's.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 09-28-2013, 05:51 PM   #5
lonewolf
i think charlie ny nailed it.
do the air fuel mixtures screws hit the intake on the rear carb?
maybe sell the 92's and put on 97's thats what i did still have some 92's if anyone is interested
lonewolf is offline   Reply With Quote
Old 09-28-2013, 05:51 PM   #6
uncle max
uncle max's Avatar
Knock knock...
Originally Posted by Charlie ny View Post
4t,
Charlie ny
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 09-28-2013, 06:18 PM   #7
ken ct
Everybodys got there own opinions LOL . Go for it you can always change it or them.I also have dummy PV's and bigger jets in the .044 to .050 range You will need bigger than stock jets if you blockoff the PV's. ken ct omo.
Old 09-28-2013, 06:59 PM   #8
jim1932
jim1932's Avatar
I guess I have a lot to learn.... Holley made 81's too?
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 09-28-2013, 08:17 PM   #9
Vergil
Vergil's Avatar
I like to tune with a AFR meter and O2 sensor, It will let you know what is happening as you drive, rich or lean and at idle. Under a load you can see if your power valves open to early or late. I think one problem when running 4x2's is when you crack open the throttle to start from a stop, very little throttle movement lets in a lot of air at low rpm. I have my throttle foot pedal set up so there is very little linkage movement until the pedal moves about half way to the floor and then it opens fast. A Unisync is a must for me to sync all the carbs at idle.
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 09-28-2013, 08:38 PM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
While we are on the subject, you all know it's hard to get you fingers in between those carbs to ajust the idel screws. I used to have tool that was long and a right angel on the bottom with a screw driver thingy. You could turn the handle to ajust the carb. Does anyone know where I could get one of those. I tried Snap On, no luck. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-28-2013, 08:48 PM   #11
Vergil
Vergil's Avatar
Something like this Walt ... http://www.amazon.com/Milwaukee-48-3...690023-1252563
Old 09-28-2013, 08:48 PM   #12
jdl
jdl's Avatar
Send a message via ICQ to jdl
Walt, a flexible chevy point adjusting tool might work for you ( the kind you can adjust through the dist cap window) ebay has some, here is a example....
http://www.ebay.com/itm/NEW-GREAT-NE...r#ht_750wt_679
jdl is offline   Reply With Quote
Old 09-28-2013, 08:52 PM   #13
Charlie ny
Verg,
You got it....zilch for vac off idle and the PV's open or at least crack open a bit. With Strombergs the power circuit is mechanical with just bit of hydraulic tingle. OMO.
Charlie ny
Old 09-28-2013, 08:58 PM   #14
Vergil
Vergil's Avatar
Verg,
Charlie ny
Charlie you are correct on the Stromberg power valve .... my bad, had 94's in my mind ... thanks for the nudge ...
Old 09-29-2013, 08:27 AM   #15
Walt Dupont--Me.
Originally Posted by Vergil View Post
Vergil. I think that power tool would be a little rugged for adjusting idle air screws. I have one of those flexable ones but with 4 carbs you still cain't keep it in the slot of the screws. The one I used to have years ago was about a foot long and rigged with a 90 degree on the end with a little cup on the end that went over the head of the screw and ingaged in the slot in the screw. You turn the handle of the tool. Walt
Old 09-29-2013, 10:35 AM   #16
4tford
4tford's Avatar
Ok, It seems as nice as these carbs are they are wrong for the application. Would they be better used on a dual setup or am I wasting a sort of rare carb. What should I do with them.
Old 09-29-2013, 02:57 PM   #17
Walt Dupont--Me.
It would be nice to know what else is in the engine, or is it stock. I believe those carbs are Holley 92 The 92 was made for the 60hp 136ci engine. I've never had one but I know there smaller venture than the 94's. I see no reason they cain't be set up with direct linkage. I don't know what the jet size is stock but I'd start out with 2 steps smaller, and probably 4.5 power valves. Walt
Old 09-29-2013, 03:10 PM   #18
4tford
4tford's Avatar
at the moment there is no engine
