06-10-2019, 02:48 PM | #1 |
HF infrared gun reviews
Hi All,
Anyone have any reviews good or bad about the Harbor Freight Infrared gun? I may get one to verify the rad temps. Thanks, Mike
06-10-2019, 02:55 PM | #2 |
Re: HF infrared gun reviews
I bought one and it seems to be pretty accurate.
06-10-2019, 03:12 PM | #3 |
I got one and I've used it for all sorts of stuff from checking brake rotors to melting chocolate (yes, you really need to immerse a thermometer to properly measure the chocolate, but it gets me a quick reading - when I need to immerse a thermometer, I use my tire pyrometer).
I bought it checked my rotor temps and it confirmed I had a sticking caliper - paid for itself the day I got it. Steve |
06-10-2019, 04:55 PM | #4 |
Mine's worked great for years.
06-10-2019, 05:56 PM | #5 |
I have the HF one at home, and one from the Snap-On truck at work. They work equally well. The HF one actually has a finer laser dot.
06-10-2019, 06:49 PM | #6 |
I have found I have to stand at least 4 ft. away from what I am measuring if the motor is running. Also on mine (not HF) really can not see the laser in direct sunlight. |
06-11-2019, 07:35 AM | #7 | |
I was not planning on using mine more than a limited few times, and bought a very cheap one. Guess I got what I paid for since others here have not had the same issues. |
06-10-2019, 10:01 PM | #8 |
My HF unit is about 5 yrs old, no problems and accurate as well. As a plus my cats like running after the laser (just don't shine it in their eyes!
06-10-2019, 10:05 PM | #9 |
I like it.
06-11-2019, 12:13 AM | #10 |
My HF temp gun has no issues being used close to the running engine and it seems to be pretty accurate
06-11-2019, 07:04 AM | #11 |
Mine has worked fine for many years. Chap
06-11-2019, 07:31 AM | #12 |
I have a Ryobi, got it from HD for less than $30. Works great!
06-11-2019, 07:36 AM | #13 |
Not trusting HF, I went to Lowes for mine. I rebuilt my rear and wanted to measure the heat rise. At 80 ambient, it was only 110 after climbing a long hill. These can be used to figure out the timing also. I was not advancing the timing enough and getting over 200 after climbing the same hill. It was over200 at the top of the radiator and about 170 at the bottom. I don't know what the heat rise should be, but it normally runs about 180.
Terry |
06-11-2019, 09:13 AM | #14 |
Thanks folks. I just put a new head gasket on and I don't want to do it again due to overheating. Especially since I cleaned things up.
Mike
06-11-2019, 10:54 AM | #15 |
I have a few of them and they work fine. I try to wait and save using coupons or buy when on sale. Recently bought one of their Ames brand on sale for $9.99 and it works fine. You have to buy a 9 volt battery for the Ames, does not come with it.
06-11-2019, 02:52 PM | #16 |
For the price it will get you in the ball-park.
Paul in CT |
06-11-2019, 08:46 PM | #17 |
Keep in mind that those measure the temp of radiated heat waves. Different colors radiate differently, as do irregular surfaces. Black is the best color to measure.
Just a warning, you might want to consider.
Corley ----------------- Subscribed to the KISS principle! |
06-11-2019, 09:23 PM | #18 |
the ones on amazon for $14 work well too.
06-12-2019, 10:12 AM | #19 |
Will they tell if your Chicken is DONE???
Bill Hungry
06-12-2019, 10:28 AM | #20 |
NO, you need a probe type thermometer for that, as you need to read the temperature INSIDE the meat.
